I was wondering if it is possible to just get the rear rotors only, turned? The rears are the only ones I am having problems with as far a continuous chirping and dusting.
I did a brake job recently ( 5K ago) and didn't turn the rotors, because I felt they looked and felt exceptionally smooth. The fronts are fine but the rears dust up big time and I get chirping noise at low speed.
bcgreen, you expected to get less dusting by having the rotors cut? Did that do anything to help the dusting? I would totally not expect it too.
Quote:
I don't know if having the rotors turned will solve the dusting problems. I didn't turn the rotors when I did the job. The fronts work fine, but the rears squeak a little and they dust alot, so much so that I have to clean them every 2 days. The fronts are as I would expect - they don't need any cleaning, except for every couple of weeks.(hardly any dust at all)Originally Posted by obsdnoblivion
That is usually a combination of your pad and rotors but mostly your pads. If you want less dust get different pads, that might also help your squeak.
Quote:
These are ceramic pads from CarboTech.Originally Posted by Dubi2087
Quote:
Different pads like Hawk HPS will have less dust.
I know most people talk about Hawk, but I felt differently and went with CarboTech performance pads and as you can see I have hardly any dusting on the fronts.Originally Posted by ttrank
+1Different pads like Hawk HPS will have less dust.
Im not a big fan of Hawk, if i were you i would just get the same thing in the rear that you have in the front.
Quote:
I have the same ones all around, installed at the same time.Originally Posted by Dubi2087
