ABS Self Test Sound during normal braking after camber kit install
Old Jan 19, 2009 | 12:10 PM
absolutg's Avatar
workin...
I got the SPC front and rear kits installed last week. The ABS/Slip/VDC lights were tripped, so I asked my tech to fix the alignment of the sensors as per the suggestion in the THMotorsports thread. We went out for a drive and checked the MPH on all 4 corners by tapping into the ECU. The front right was off a little but we got it close enough so that the ABS/Slip/VDC lights would not trip.
I drove around all weekend and didn't really have any major issues until I started hearing a sound very similar to the ABS self test sound you hear right after starting the car and moving at about 5mph. I hear the sound most frequently slowing from 45 mph to a stop and I feel a little shudder in the brake pedal. I can't reproduce it every time but it occurs with some regularity and my wife noticed it too.
What is causing this? I need to have some ideas before I go see my tech tonight to get the rear toe bolts put in.
Thanks!
Old Jan 19, 2009 | 02:31 PM
absolutg's Avatar
workin...
bump again
Old Jan 19, 2009 | 11:46 PM
absolutg's Avatar
workin...
bump, plz help
Old Jan 20, 2009 | 03:51 AM
codeflux's Avatar
wait, so, your suspension is to spec (all aligned to factory specs) but you're experiencing brake problems now... i can't come up with any explanation... subscribed for other members' feedback.
Old Jan 20, 2009 | 01:20 PM
absolutg's Avatar
workin...
yeah everything is in spec except for my rear toe (-.37/-.38)
Old Jan 20, 2009 | 01:28 PM
codeflux's Avatar
hm that toe looks a bit off. could be the cause, although i don't see how it could...
Old Jan 20, 2009 | 02:18 PM
absolutg's Avatar
workin...
it's off because i'm waiting to get the toe bolts installed but i don't think it should be causing this problem. the jarring sound is coming from the front and i wonder if it has to do with the alignment of the abs sensors ?
Old Jan 20, 2009 | 02:26 PM
baileyrx's Avatar
did they reinstall the tires correctly. (fronts/backs?)
Old Jan 20, 2009 | 03:03 PM
codeflux's Avatar
ah. yes. provided you're not staggered.
Old Jan 23, 2009 | 12:30 PM
absolutg's Avatar
workin...
i'm staggered but i will check that. i'm pretty sure they just dropped the tires closest to the install points and put them back on
Old Jan 25, 2009 | 01:02 PM
absolutg's Avatar
workin...
any help people? still totally stuck with this problem and i might have to hit up the dealership
Old Feb 13, 2009 | 01:34 AM
simple_drive's Avatar
i would check all wheel speed sensors and connectors just to make sure nothing is loose, these simple things can trigger your light
Old Feb 19, 2009 | 04:55 PM
codeflux's Avatar
what's the size of your wheels and tires?
Old Feb 19, 2009 | 11:06 PM
absolutg's Avatar
workin...
happened on my 19s and 17s. i just got the problem fixed on monday. took off the unnecessary SPC bracket and spacers. everything's dandy now.
Old Feb 19, 2009 | 11:57 PM
codeflux's Avatar
great to hear! extra stuff is never good. /me unsubscribed.
chinee
Jun 10, 2024 07:48 PM
kd03g99
Jul 30, 2015 11:24 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
nascarbuff17
Jul 16, 2015 10:23 AM
