Lowering my G HELP
^ no problem man.
i'm a fan of the SPC kits - i've seen many members here are running those. they are pretty inexpensive and seem to be great quality from the reviews i've seen. check out this sponsers thread for an idea on prices and to order.
I'd get the SPC rear camber kit, i think BHautosports or w/e their name is (sponsor on here) sells them for a good price. The install is difficult because you have to drill out the hole for the toe bolt, so I'd recommend getting a local member to do it for you, b/c shops will charge you a ton once they realize what they have to do. You can pick up a set of used springs in the marketplace for cheap and get springs/camber/install/alignment for around $500-600
my alignment checked. Then I invested in Cusco adjustable A-Arms for the
front and their rear adjustables camber bolts. After alignment it came back
to OEM specs. Without it my alignment was waaaaaay off. Consider it
cheap insurance when you check the cost of quality tires!
Gary
Does anyone know if I will need to get the camber adjustable front arm?
I drive a 2005 G35 coupe. I am dropping my car about 1". I figure I will need the following:
1) Eibach ProKit springs
2) Rear Camber kit.
The front camber is like 300 bucks +. I was just wondering if it was necessary?
2) Rear Camber kit.
2) Rear Camber kit.
2) Rear Camber kit.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
