Sedan - when did you replace rear brakes?
Old Feb 25, 2009 | 01:21 PM
blownvert's Avatar
i have a 04 with 53k and i just replaced the rear rotors and pads. i have already replaced fronts before. that seem about right? he said i needed it, it was getting thin
Old Feb 25, 2009 | 01:46 PM
Jeff92se's Avatar
Red Card Crew
Not unusual. Remember the VDC operates by activating the rear brakes. So rear wear is not dictaticed by amount of brake activation via the brake pedal.
But I have 60,000 and my rear pads looked worn. But I went ahead and put 06 Z brakes all around.
Old Feb 25, 2009 | 03:26 PM
RADIOGUY21's Avatar
not bad at all if those were the original pads and rotors in the rears, but likely you were on the second pair of pads at least.
Not uncommon for the fronts to outlast the rear, mine did. I resurfaced my original rears at 36K miles. Have 43K now on original fronts and still have some decent pad left.
Old Feb 25, 2009 | 04:14 PM
FenixL1P's Avatar
my rear pads were worn down to the backing plate. fronts had at least another 7.5k-10k miles left in them. I'm at 62k but thought i change them out (including rotors) anyway due to pulsing ("warped") feel.
Old Feb 25, 2009 | 04:55 PM
g35freak86's Avatar
normal. I Just replaced my rotors and pads at 61k
Old Feb 25, 2009 | 06:13 PM
hg35x's Avatar
re : "the VDC operates by activating the rear brakes" Can you explain how that works ?
I didn't know that. So if my VDC comes on a lot I will have to replace my back brakes before my front brakes? Makes sense.
Old Feb 25, 2009 | 06:23 PM
SVTCOBRA's Avatar
05 Sedan: replaced rear pads at 30K and they were thin.
fronts are OK, but going to turn the rotors and replace pads this weekend to hopefully get rid of the pulsating.
The sedan has never been run hard and I keep my wheels torqued to specs.
G35 brakes SUCK!!! (at least mine does)
But, rest of the car is
Old Feb 25, 2009 | 07:27 PM
jack_burton's Avatar
actually g35 brakes are one of the best in business. The braking power is unheard of for a car in the price category. Just remember the most powerful the brakes the more they wear out
Old Feb 25, 2009 | 07:35 PM
xratedg's Avatar
I also have an 04x with 53k and just had the front/rear brake pads and front rotors replaced. The back rotors were resurfaced instead of replaced.
After having all this fixed, I cannot believe how powerful these brakes are (especially for a sedan)!
Old Feb 26, 2009 | 10:56 AM
RADIOGUY21's Avatar
the brakes on our cars are very good for a sports sedan. Only downside is the increased wear.
Old Feb 26, 2009 | 11:00 AM
AARONHL's Avatar
My front brakes dust like crazy, the rotors are made in China so I'm sure that doesn't help. I'm using OEM break pads, Chinese rotors, and brand new shim kits. Anything I can do?
Old Feb 26, 2009 | 11:08 AM
MidnightG35X's Avatar
Back wearing faster than the front? I find that REALLY hard to believe. Most of the braking force comes from the front brakes, not the rear. This is true for almost EVERY car in existence. When you brake, all your momentum shifts towards the front of the car, making the front brakes work harder than the front. This is also why almost every car has larger front brakes compared to the rear.
I'm right around 50k, fronts need replacing soonish (on second set of pads) and rears still have plenty of pad left (also second set).
The VDC only working the rear brakes is only partially true. The traction control part of it this is true, but not true for the stability control. See below from the service manual:
TCS Function AFS0003Z
1. VDC/TCS/ABS control unit detects a spin at drive wheels by comparing wheel speed signals from all 4
wheels. At this time, output from control unit controls brake fluid pressure to both LH and RH rear wheels
while cutting fuel to engine and closing throttle valve to reduce engine torque. Furthermore, throttle position
is continuously controlled to insure appropriate engine torque at all times.
2. Depending on road circumstances, driver may have a sluggish feel. This is normal, because optimum
traction has highest priority under TCS operation.
3. When vehicle is passing through a road where surface friction coefficient varies, downshifting or depressing
accelerator pedal fully may activate TCS temporarily.
4. During TCS operation, it informs driver of system operation by flashing SLIP indicator lamp.
VDC Function AFS00040
1. In addition to TCS/ABS function, VDC detects driver's steering operation amount and brake pedal travel
from steering angle sensor and pressure sensor. Using information from yaw rate/side G-sensor and
wheel sensor, VDC judges driving condition (conditions of under steer and over steer) to improve stability
by controlling brake application to 4 wheels and engine output.
2. SLIP indicator lamp flashes to inform driver of VDC operation.
3. During VDC operation, body and brake pedal lightly vibrate and mechanical noises may be heard. This is
normal.
4. If vehicle is rotated on turn table, or rolled and rocked on ship, ABS warning lamp, VDC OFF indicator
lamp, and SLIP indicator lamp may turn on. In this case, start engine on normal road again. If ABS warning
lamp, VDC OFF indicator lamp, and SLIP indicator lamp turn off after restart, it is normal.
5. When driving in steep slope such as bank, ABS warning lamp, VDC OFF indicator lamp, and SLIP indicator
lamp may turn on. In this case, start engine on normal road again. If ABS warning lamp, VDC OFF indicator
Old Feb 26, 2009 | 12:09 PM
dfrancisco's Avatar
I'm at 37k and my rear brakes are just about ready for pad replacement. I'll get it done during my next service at 40k. Apparently my front brakes are still fine.
Old Feb 26, 2009 | 01:35 PM
ttrank's Avatar
Grocery getter
I'm impressed yours are lasting that long!
Old Feb 26, 2009 | 01:39 PM
Jeff92se's Avatar
Red Card Crew
IMHO, in order for our Gs to get the world class braking, the rears are much more involved with the braking process than in previous nissans/infinitis. Thus accelerating it's wear. IMHO of course.
