Sedan - when did you replace rear brakes?
Old 02-26-2009, 02:32 PM
phrocker's Avatar
when the wheels are spinning (as a result of no traction) they aren't supporting the weight of the vehicle, so it doesn't take much pressure to slow those wheels to that of the front. I doubt that it affects rear brake life dramatically
Old 02-26-2009, 03:53 PM
SVTCOBRA's Avatar
Originally Posted by jack_burton
actually g35 brakes are one of the best in business. The braking power is unheard of for a car in the price category. Just remember the most powerful the brakes the more they wear out
Sorry, but strongly disagree with you.
I'm specifically talking about the rear pads wearing out too quickly (30K miles) and the front rotors warping for no apparent reason other than lack of quality.
I'm not sure what you are used to, perhaps this is the best you have experienced.
I'm hoping the new pads that I just put on will do better!
If the pulsating comes back, I'll purchase a better aftermarket set of rotors.
Old 02-26-2009, 04:09 PM
RADIOGUY21's Avatar
Like I said earlier, my fronts have outlasted the rears in my 05. I think for the 2005 RWD, and 2006 models, Infiniti "overdid" the front brakes to address the concern of dusting and pre-mature wear from previous years, which may result in the fronts outlasting the rears.
Old 02-26-2009, 04:54 PM
SVTCOBRA's Avatar
it is very strange that the rears die before the fronts...If I DID have excessive dust, I would understand it better. But, I hardly have any dust on the Sedan wheels.
When I bought my coupe (used), the dealer had just put on new Nissan pads.
They produce a TON of dust, but stop on a dime. Very performance oriented.
But, more dust that I would like. When the pads on the Coupe wear out, will probably go with some Hawks. But, got plenty of time.
Old 02-26-2009, 04:58 PM
Jeff92se's Avatar
Red Card Crew
Very aggresive pads are what allowed a 3400lb sedan on 11.5" rotors to stop in 110 ft from 60mph.
In 05, the sedan stopped in 111ft from 60mph, with much less dust and much less wear on the rotors. But with the same cold 1 stop performance as before. Which is why I upgraded to these brakes
Old 02-26-2009, 05:24 PM
dofu's Avatar
I changed my brake pads out at 30K, and again at 70K. While the rotors looked fine, I changed them out at 70K anyways.
Old 02-26-2009, 10:36 PM
blownvert's Avatar
i probably wont have to change front or back again get rid of the car before im sure
Old 03-31-2009, 06:02 PM
sodal's Avatar
Brakes Brake Hell
I have an 04 with 35.5 and have already replace the front brakes n rotors at 18k. I'm being told by the dealer that I need both replaced again and pads on the rear. Can this be possible? Can I get brakes that will last longer? Not a gear head-- appreciate any feedback.
Old 03-31-2009, 09:38 PM
blownvert's Avatar
umm highly unlikely, i actually just had my rears done at 54k rotors pads that was first time and i got the front done i believe around 40ish. i will probably not need the rears down ever again sell the car before and probably just front pads
Old 03-31-2009, 09:47 PM
ELMACHOGERACHO's Avatar
the ft brakes on 03-04 g's are complete garbage. the pads are much too agressive for the rotors, thus causing "short" life.
from my experiences, most g's go 30-40k on rear pads. in fact that how most infinitis wear their rear brakes.
Old 03-31-2009, 09:53 PM
Swivel's Avatar
Moderator
Wondered why you bothered if you're gonna sell it in the next 5 minutes.
Old 04-01-2009, 09:53 PM
blownvert's Avatar
im not gonna keep the car past 90-100k probably so umm no need to change again
Old 04-03-2009, 07:18 PM
Jeff92se's Avatar
Red Card Crew
60-0 in 110ft is "garbage"? Not bad for tiny arsed 11.5" front rotors.
Old 04-04-2009, 09:21 AM
UMBG35's Avatar
On my 05 coupe (5at, sport suspension) I changed out my rear pads at 35K and the fronts at 40K (both with OEM) and didn't resurface the rotors. I don't track or anything crazy like that...this is my daily driver bought the car in 1/06 with 12 miles on it. They have 80K on it now and no "squealing" yet. However, I don't know if these rotors were intended to be run this long without changing them out. What do you guys think? I haven't measured the rotors width and probably won't. I'll probably change out the rotors and pads in the next month or so. I decided to change out the rotors/pads early after driving my friend's stock 07 TL and realized how much initial bite I've lost on my brakes...feels like a sponge actually in comparison.
I've been looking into getting centric blanks with hawk hps pads. Entertained getting DBA 4000XS (they look pretty sick) with Hawk HPS but I have a feeling the drilled areas will crack within 50K. If they last me 50K, I'd be happy but I've seen lots of cracked drilled rotors ranging from G35s to AMGs way before that. But I'm thinking maybe I should just stick with OEMs for both rotors and pads since they've given me 80K of service without problems. These are my only three options... Any recommendations?
Here is the link to the centrics:
http://www.zeckhausen.com/Infiniti/G35-2.htm
Anyone know of a good site for the DBAs?
rezendvous420
05-31-2020 01:26 PM
silencedeyes
Brakes
11-26-2015 05:36 PM
emorehs
07-17-2015 09:45 AM
nascarbuff17
07-16-2015 10:23 AM
mushu
07-15-2015 03:55 PM
Quick Reply: Sedan - when did you replace rear brakes?
