Life expectancy of stock shocks
Old Mar 3, 2009 | 11:17 AM
esfoad's Avatar
My car just turned 84K miles today. I was wondering what the life expectancy is of the stock shock absorbers. I feel my car bounces more than it did in the past and I am hoping to keep the car. Thoughts? I searched but could find no reference to this.
Old Mar 3, 2009 | 02:17 PM
5150DS's Avatar
From what I have read shocks last from 30-60k and struts last up to 80k. I would say you are due.
Old Mar 3, 2009 | 03:35 PM
ttrank's Avatar
Grocery getter
I would change them.
Old Mar 3, 2009 | 03:52 PM
esfoad's Avatar
Sounds about right. Tire Rack has KYB's for about $300 for 4. DO you guys have a preference? I want to stay low in price, keeping the stock ride but not sacrificing quality.
Old Mar 3, 2009 | 04:17 PM
G35 Mass's Avatar
30-60k? Ha, I'm due! I've got a lot of suspension work ahead of me. Shocks / struts, sway bar end-links x4, compression rods x2, and a bad feeling about some bearings up front..
Old Mar 3, 2009 | 04:18 PM
Ralph0064's Avatar
__________________
if I were you, I'd just pick up some tokico blues from THMotorsports.
Sale thread: https://g35driver.com/forums/suspens...t-d-specs.html
Old Mar 3, 2009 | 06:03 PM
5150DS's Avatar
I just ordered those from them (350z version) and an HKS rear section.
Old Mar 3, 2009 | 06:05 PM
5150DS's Avatar
If you are planning on lowering, I would do both at the same time. Why pay someone twice.
Old Mar 3, 2009 | 06:13 PM
Jeff92se's Avatar
Red Card Crew
I was never impressed by the reply from the vendor selling the tokico blues. I ran blues on my old maxima and they were worn out when I pulled them to run Konis. If you just want stock oem replacements, they might be okay.
I have a set of low miler coupe shocks for sale. I was going to run them before I got a set of Koni adjustables.
But since you are AWD, I don't think the fronts will work for ya.
Old Mar 3, 2009 | 07:41 PM
jack_burton's Avatar
Koni's are obviously better you are paying over double what you would pay for the tokico blues. You get what you pay for. But the blues are significantly better than the OEM sport and non sport shocks from infiniti which use Tokico as the OEM. People say they are exactly the same but they are NOT. Look at the housing and you'll notice they are wider than the OEM. Plus I've talked to the manufacturer and they said the Blues are valved for high dampening for better performance. I have them and they run well with my coupe springs. just FYI
Old Mar 3, 2009 | 08:25 PM
esfoad's Avatar
Thanks for all the replies. I've got a PM out to get pricing and availability of the Tokico HP Blues.
Old Jun 1, 2009 | 01:46 AM
Skyfox16's Avatar
So did you end up getting the kyb's from tirerack? how do you like them?
they are running a 10% off deal for the set now that makes it $275 shipped for all 4. and i was thinking about replacing mine because it seems to bounce more than i am used to in other cars.
Old Sep 14, 2010 | 12:50 AM
GYAL8R's Avatar
Cali Event Coordinator
BASE ACURA TLX NOW WANT A G35 AGAIN THOUGH
got a 2004 g35 with 121K "stock shock absorbrers" minor squeeks once in a while..dealer wanted $365.00 rears each side no thanks..i'll just go after market and finally lower it by 1/2" ...hopefully by end of the year or next spring...why replace it if it's not broken..just minor leaks that's alll no biggie..
Old Sep 15, 2010 | 11:58 PM
tonke73's Avatar
I had 92K on my g35 and the oem stocks were still going strong with no signs of leaks. So much depends on the climate that you live in and the condition of the streets that you drive on.
Old Dec 23, 2011 | 11:24 AM
snowtrax's Avatar
I can't imagine the typical life of shocks is less than 100k. I have a 2000 328i driven decently hard its entire life and has 132k on original shocks. My '05 X has 98k and drives the same as my '08 X and I live in New Hampshire where the frost heaves can get nasty. I don't know where you guys are coming from but 30-60k seems way early.
