Front camber issues
Old Mar 13, 2009 | 05:52 PM
repin_LB's Avatar
Front camber issues
Hey guys. So i LOVE my drop i have on right now but unfortunately i think this is cause lot more problems later like tire wear...So i just dropped my car on megan coilovers about 2.2" in the front and im prob going to bring it up so i have a 1.6-1.7" drop. I was wondering if this drop will cause a really bad tire wear? Would i need a front camber kit? Would i be able to get it into factory specs? thanks guys
Old Mar 13, 2009 | 06:12 PM
TheTick's Avatar
It will definately cause camber wear but not as bad as a 2.2" drop. If you don't want to get a camber kit, its all about balancing how low you want to go and how often you want to buy new tires.
Old Mar 13, 2009 | 06:20 PM
tragedycat's Avatar
Yes, it is a sizable drop and you will have bad tire wear. There is no OEM adjustment whatsoever up front so you won't be able to get it back into spec. Most likely you will need both front and rear camber kits.
Old Mar 14, 2009 | 06:54 AM
repin_LB's Avatar
so when people actually say i will have bad tire wear. like how bad is bad? how many miles will i get on the tires? cause tired usually last for about 20k miles right?
Old Mar 14, 2009 | 03:38 PM
TheTick's Avatar
Depends on your driving style. If you have a lot of negative camber your tires can wear 4 times faster. The wear actually happens on the inside of the tire so you can have a shop flip them and get more use out of them as long as the tires are not unidirectional.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
