Camber adjustment
Old Mar 16, 2009 | 04:42 AM
Heinz's Avatar
Camber adjustment
As i am soon about to install my new 350z Tein S-Tech`s and rear camber kit, and toebolts, i would very much like to know the correct measurements, for the rear and front
Old Mar 16, 2009 | 07:00 PM
slizzap's Avatar
Just an FYI. After lowering your car your rear camber should still be within spec. It's your fronts you'll need to take care of. I lowered my car with Tein's last year and had really bad uneven wear on the fronts. I just replaced my tires and got a wheel alignment. The rears are fine but the fronts can't be adjusted to get them within spec...so now I'm looking into getting a front camber kit.
Old Mar 16, 2009 | 08:50 PM
PTownG's Avatar
proper spec range is the same as it was before you lowered it. You need the camber kit to get back within that range.
Old Mar 16, 2009 | 08:52 PM
bigc's Avatar
Wings Nation
factory alignment specs:
https://g35driver.com/forums/brakes-...ons-specs.html
Old Mar 17, 2009 | 01:07 AM
Skaterbasist's Avatar
Retired SuperMod
My rears are certainly not within spec after a drop.
Old Mar 17, 2009 | 01:18 AM
slizzap's Avatar
Depends on how much you lower it. In any case, the rears can be adjusted while the fronts cannot without a camber kit. So at the very least he will definitely need a kit for the fronts. He only mentioned doing the rears, figured it was worth mentioning.
Old Mar 17, 2009 | 04:32 AM
Heinz's Avatar
So you guys say that the fronts are more out of spec, than the rear, after installing the 350 S-Techs, and you can adjust the rear some, but not the fronts, without the camber kit
Old Mar 17, 2009 | 03:24 PM
PTownG's Avatar
I have the same s-tech 350z springs.
Needed rear camber kit
Old Mar 17, 2009 | 03:41 PM
Heinz's Avatar
So the tirewear is less in the front than rear?
Old Mar 17, 2009 | 06:39 PM
PTownG's Avatar
I don't have a front kit and I just replaced all 4 original tires that had 15k stock miles and 15k lowered miles on them. The fronts and rears were pretty equal as far as wear.
Old Mar 17, 2009 | 07:33 PM
HipHopPro's Avatar
Before the S-Tech G35 Springs, only the rear had badd wear, the front had some wear, but not has bad has the rear (front 20% wear & the rear was like 65-70% wear). What's funny about that is the front has a 1.2 drop & the rear only has a 0.9 drop
Old Mar 19, 2009 | 06:18 PM
Heinz's Avatar
Ordered the 350Z Tein S-Techs and the SPC rear camberkit, with toebolts today, will see how much the wear in the fronts gets, before i order the front camberkit
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
