Question: can i lower my car with 10.5 in the rear?
Hello,
Sorry for the newbie question. I tried to search but couldn't find the answer. I'm planning to lower my car but the rear wheels are 19x10.5 with 22offset wrap with 295-30-19. The wheels stick out a little bit, i was wonder if it will be a problem if i lower my car?
the fenders are already rolled and im thinking about the tein basic.
any help would be great! thank you!
the fenders are already rolled and im thinking about the tein basic.any help would be great! thank you!
Even if you realign the car close to specs after a drop, I don't think you should have an issue if the fenders are rolled.
I have a 10.5" rear wheel with +18 offsets on 275 rubber. I can't even stick my fingers through the fender and I still don't rub. And my fenders aren't rolled. Once I get my alignment done though, I will definitely have to roll them.
i rolled my fenders because it was rubbing when i hit the bumps. maybe when i lower the car, i should change the tires to 275 or 285. Would that help?
you will be fine i have the same offsets and tires (volk ce28n's w/ kumho ecstas) and im on tein basics. if your fenders are rolled you will be absolutely fine. it will look great too!
im thinking about lowering it 1" rear and 1.5" front. Something that give the 1 finger gap all around.
If your going with coilovers, I'd say start with a little drop and keep going until it get where it look great with the rims. Right now I have 1" and 1.5" on stock 18's, just bought 20's 10.5 in the back, May drop more, we'll see. Go coilovers for adjustability
bump... i decided to go with 350 htech for now....
i have 19x10.5 22offset with 295-30-19, i'm planning to lower it with 350z htech. I was wondering if i will have any problem? oh yeah, i wont be doing the spring mount mod. any help would be great. thanks
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
