Relentless Autosports STB Resolution ONLY
Old 06-03-2009, 11:15 PM
Cubanl81's Avatar
+1 on modded stockbox. Still have to install mine and don't want aftermarket intake.
  #107
Old 06-03-2009, 11:37 PM
Beebo's Avatar
xx7sephiroth7xx can i have pics of the stillen airbox and a DIY?
...Please?
Thanks man
  #108
Old 06-04-2009, 02:54 PM
psedog's Avatar
Back in SD**
Some quick snaps. Been kinda busy. Went to Tokyo Disney yesterday. Went to the hospital and shopping today. When we returned today I took some time out to wash, D/A Polish, and wax her (~3 hours of quality time ). Forecast calls for rain for at least the next 10 days
  #109
Old 06-05-2009, 06:55 PM
Beebo's Avatar
Thanks for the pics. how did you modify it?
  #110
Old 06-06-2009, 11:36 AM
psedog's Avatar
Back in SD**
I pretty much cut off the bottom half
I'm going to modify the bottom to run a tube to my side opening in my Kurookie Sedan Bumper. I'm going to see what I can do to modify my Snorkel so that I can still use it with it. If I can't do it, then I'll seal up that side so that it doesn't pull in hot engine air.
  #111
Old 06-06-2009, 09:52 PM
Beebo's Avatar
i see
  #112
Old 06-07-2009, 01:15 AM
xx7sephiroth7xx's Avatar
G
Sorry I got back to you so late & please excuse the slightly dirty engine bay.
The only modification I can remember that I made to my Stillen airbox was to push over the airbox toward the front of the car (not quite sure, can't really remember, but it'll make more sense if you have the box and you're installing it) & re-drill a hole that mounts near the fender. See? No cutting of snorkel required. [Again, props to my bro PJ for helping me figure this out]
I turned the MAF sensor so the plug now faces downwards.
Hope that helps.
  #113
Old 06-07-2009, 01:38 PM
Beebo's Avatar
Thank you sir
  #114
Old 06-07-2009, 08:30 PM
G
Originally Posted by Beebo
Thank you sir
Sure thing.
If you've got any questions, don't hesitate to ask.
  #115
Old 06-08-2009, 12:07 AM
Beebo's Avatar
will do man when i have time to install lol
  #116
Old 06-09-2009, 11:59 AM
LowUFO's Avatar
I'm having a hell of a time trying to install my STB. I have a Vortech supercharger, and can't get a wrench on the lower nut on the drivers side bracket. It looks like I will need to pull the supercharger, and install the STB before reinstalling the SC. What a pain in @ss. It also looks like the bracket that holds the cross bar may still hit the cog belt on the back of the SC. I'll probably need to grind a little of the bracket to clear the belt. It looks like it may be months before I get this thing installed. Was there anyone else with a SC that had install issues?
Ian
  #117
Old 06-09-2009, 04:19 PM
G
Sorry to hear dude, that's pretty ridiculous.
  #118
Old 06-09-2009, 09:11 PM
viceversa's Avatar
anyone know if the driver side bracket is the same for N/A and SC?
  #119
Old 06-10-2009, 05:20 PM
Beebo's Avatar
i got my bar installed today by speed factory here in el paso texas and the only modification that had to be done was drill a new hole that mounts near the fender and relocate the ac line but thats it
my only complaint is the piece of metal in the tubing its annoying
  #120
Old 06-13-2009, 01:40 AM
G
Oh, so you didn't do it yourself?
I keed, I keed.
Yes, I have that same piece of stupid metal. I'm surprised Scott let TWO out like that.
Also, when you say "drill a new hole that mounts near the fender," are you takling about drilling a new hole in the Stillen heatshield?
*EDIT* Also, do any of you guys have any extra vibrations in the cabin that you can hear and/or feel through the steering wheel??
Quick Reply: Relentless Autosports STB Resolution ONLY
