Relentless Autosports STB Resolution ONLY
#123
Oh, so you didn't do it yourself?
![Icon17](https://g35driver.com/forums/images/smilies/icon17.gif)
I keed, I keed.
Yes, I have that same piece of stupid metal. I'm surprised Scott let TWO out like that.![Mad](https://g35driver.com/forums/images/smilies/mad.gif)
Also, when you say "drill a new hole that mounts near the fender," are you takling about drilling a new hole in the Stillen heatshield?
*EDIT* Also, do any of you guys have any extra vibrations in the cabin that you can hear and/or feel through the steering wheel??
I keed, I keed.
#124
#125
I finally got the chance to upload my photos from the issues I was having. As you can see in the pics, I am like 1mm off on the hole for the cross brace, just need to pull on the bar harder or make that hole a little bigger. The thing is, by doin this, the bar seems to be slightly shifted closer to the drivers side fender and thus the bar sits lower and rubs the wire loom in the 2nd photo, is this normal/look normal to the rest of you who have yours on?
![](http://i40.tinypic.com/xlzf2e.jpg)
![](http://i42.tinypic.com/25a4xvq.jpg)
![](http://i43.tinypic.com/2rgyw3o.jpg)
![](http://i39.tinypic.com/2uhl7gj.jpg)
#126
#128
Also, DefJukie, did you actually get the bar installed yet?
If you haven't, and since your ~1mm off, try loosening the bolts on top of the passenger side strut tower (since I assume you have the bolt and bar there together) so you can have a little more room to get the bolt on the driver's side in. After you do that, tighten the passenger side strut tower bolts.
Let me know if this works.
#129
Mine were a little bit difficult to get on as well. On the passenger side the hole either had too much paint or was drilled a little to small. I was able to work the bolt through but it took a bit of effort. There is no adjustment at all in this setup, because of this the tolerances are very tight. I honestly think this makes it better. At least you don't have to worry about the bar slipping that is for sure ![Wink](https://g35driver.com/forums/images/smilies/wink.gif)
Mine is sitting on my wire loom as well. I think I slid it forward a little so it would be sitting directly on it. Better to be safe than sorry
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
#130
#131
#132
Mine is sitting on my wire loom as well. I think I slid it forward a little so it would be sitting directly on it. Better to be safe than sorry![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Sorry.
#134
Well..... after months of having the STB sitting in my trunk, I finally had a chance to get it installed. WHAT A PAIN IN THE A$$!!! I had to pull the bumper cover, headlights, radiator support, and Vortech to get to the lower bolt on the drivers side bracket. Luckily, I had to remove most of this stuff to replace an AC line that the Vortech had worn through. If I had to go through all that just for the STB I would not be a happy camper.
So, It's finally on, and it made a noticeable difference in the way the cars handles.
Ian
Ian
#135
Ian
Ian
