What strut bar will fit with the Tein EDFC?
I ordered the GT-Spec strut bar, but was told today by the vendor that it won't fit with the Tein EDFC that I have coming. I guess the servos add to much height/diameter to allow for proper fitment. So does anyone know of a strut bar that will fit with this setup?
Seems like many members are having fitment issues with this bar.
https://g35driver.com/forums/brakes-...ent-issue.html
Do y ou have any pics of it installed in your car? Also, will it clear if I have a 5/16 spacer installed?
Does it just rub the liner or does it actually push into the hood? Is it adjustable so that if you remove the engine cover you could lower it enough to not rub the liner?
It just rubs the liner. Scuff marks are visible on the liner but it doesn't push up on the hood.
The strut bar is adjustable in height and I could adjust it a little lower, about 1/2 inch more, if I wanted.
Sorry, don't have pics. I have the Stillen with the 5/16 spacer and edfc. Work like a charm.
I have pic's of my Stillen bar, with EDFC's and a 5/16 spacer
On the left side you can see the Green of the Tein coilovers, with the black being the EDFC.
