Need ROTOR And Brake Pad installation instructions!!!
Old Apr 6, 2009 | 06:36 AM
Engineerseller1's Avatar
I searched but for some reason i feel like and a$$ and cant find any discusions with any type of links, videos, or walk through instructions!!! I have oem brake crap NON BREMBO!!! bought new pads and rotors please show me a good link or forum link with brake installation of rotors and pads!!! THANKS!
Old Apr 7, 2009 | 08:30 PM
any body can help please?
Old Apr 7, 2009 | 10:43 PM
PTownG's Avatar
there are probably no how to's because it is chimpanze easy, as in a monkey could do it.
take off the wheel, remove the 2 caliper mount bolts on the back of the caliper and slide it off the rotor. Prop it or suspend from a coathanger so it is not hanging by the brakeline. Use big c clamp while the old pads are still on to push the piston back in the caliper then pop out the old pads and pop in the new.
with the caliper off the rotor just comes off. If it is stuck spray pb blaster around the studs, let sit for an hour and whack it from the back with a rubber mallet.
slide new rotor over the studs, slip caliper back over the roter and insert the caliper mount bolts and tighten to spec.
that's it. Takes me under 15 minutes a wheel
Old Apr 8, 2009 | 01:55 PM
aussiedog's Avatar
Try this for starters. Hope it helps.
Old Apr 9, 2009 | 02:31 PM
Gargan's Avatar
yeah that
Old Apr 23, 2009 | 07:16 PM
bythabay's Avatar
video here: https://g35driver.com/forums/g35-sed...eo-series.html
Old Apr 23, 2009 | 07:30 PM
WhosRich's Avatar
^theres no front brake DIY :'(
Old Apr 23, 2009 | 07:34 PM
bythabay's Avatar
the front brakes are just like the rear ones, except there is no parking brake to mess with.
Old Apr 27, 2009 | 09:39 PM
edwin1222's Avatar
go to G sedan discussion boards, theres DIY video.
miata007
Aug 17, 2015 04:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
