GT Spec Front tower strut bar//Install help?
Old 07-28-2010, 08:43 PM
LMG_35C's Avatar
I was wondering if anybody tried jacking up the front to take weight off of the suspension to see if that made algning the bar any easier or not. Gonna install mine this weekend and if I have any issues I thought I'd give this a try as I had wanted to see what kind of flex was in the strut towers to begin with.
  #47
Old 07-28-2010, 09:00 PM
bigc's Avatar
Wings Nation
i believe i've seen some folks post about doing that. i didn't try it though since i figured, if anything, taking the car's weight off the strut towers would cause them to separate further.
  #48
Old 07-30-2010, 08:34 PM
LMG_35C's Avatar
Well that didn't work. It didn't move the towers in any direction. I finally managed to get it on like others have said..loosening all the tower nuts and brute force. 10 minutes my ahss....
1 hour to get the brackets on, struggle with bar, floor jack waste of time, remove bar, loosen brackets, struggle with bar again, success, re-tighten and finally adjust.
Then another hour to find the damn nut that dropped into what wound up to be a little pocket on the side of the passenger tower.
It was worth it though, definate difference in how it corners and rides. Seems much tighter all around.
  #49
Old 07-30-2010, 08:49 PM
WhosRich's Avatar
^Good to hear. I spent a total of an 1.5 over a 2 day span to get mine on. Totally worth it.
  #50
Old 07-31-2010, 06:02 PM
LMG_35C's Avatar
Doing some work on the caAr today, I noticed that it now looks like I've got negative camber. Could the bar have cause that? Should I be concerned / have it adjusted?
  #51
Old 07-31-2010, 06:05 PM
WhosRich's Avatar
No way the bar could cause you're car to be misaligned. It doesnt attach to anything related the steering. Just get it aligned or you might have some tire issues later on.
  #52
Old 07-31-2010, 06:49 PM
LMG_35C's Avatar
Thanks but that's not about steering. The top of the wheels look to be tucked into the wheel housings. Never noticed this before and I'm pretty familiar with everything about my car. Doesn't look serious, just a bit more negative than stock.
  #53
Old 10-07-2010, 10:40 PM
ciraleon's Avatar
I just got my GTspec strut in today... How many pounds did you guys torque it to?? Man, you guys are scaring me. haha. I thought this would be a simple **** install.
  #54
Old 10-07-2010, 10:53 PM
WhosRich's Avatar
Its pretty simple. I forgot what i torqued it to. Its in this thread though.
  #55
Old 10-07-2010, 11:02 PM
bigc's Avatar
Wings Nation
just get it good & tight by hand.
  #56
Old 01-19-2011, 07:33 PM
djfarhan's Avatar
does the strut come with 4 nuts or 6?
  #57
Old 01-19-2011, 08:28 PM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
If you're talking about the nuts that screw onto the bolts on the top of the strut, you just reuse your stockers.
North NJ G
Steering & Suspension
12
05-27-2023 01:14 AM
silencedeyes
Brakes
11-26-2015 05:36 PM
Th611
10-27-2015 03:48 PM
netcbc
Steering & Suspension CDN
07-24-2015 11:23 PM
Quick Reply: GT Spec Front tower strut bar//Install help?
