Removing rotors which are rusted on
Old May 3, 2009 | 08:57 PM
PTownG's Avatar
Originally Posted by InTgr8r
^WHS.
In this case rubber FTL
you use a rubber mallet if you are upgrading and want to be able to sell the oem's if they are still good.
A BFH would ruin them.
PB Blaster is your friend and it is not at all the same as WD40
Old May 3, 2009 | 09:32 PM
Vrod-Mike's Avatar
Why would a hammer ruin them? You're only hitting the portion of the rotor near the hub and doing so will not harm the rotor at all. Now if you hit one of the studs or did something really stupid like hit the surface where the pads sit then you could do damage, but hitting it near the hub will do no damage unless you're using a sledge hammer.
Old May 3, 2009 | 09:35 PM
naughty240's Avatar
^ agreed that has been the way its been done for years.
Old May 3, 2009 | 09:43 PM
0MGHI2U's Avatar
if you smoke.. light up a cig.... get a hammer.. take a few puffs.. then give it a good smack.. that's how i got mine off. LOL
Old May 4, 2009 | 12:03 AM
MM2K4's Avatar
nice nice...ill give it a shot tomo after work...
Old May 4, 2009 | 12:54 PM
thatguy II's Avatar
Put a pryber between on one of the caliper mounting lugs and the back of the bar against the inside of the rotor. Put enough umph on it to just tension the rotor, you can see it just starting to flex. With the rotor tensioned, hit straight down on the center hub of the rotor with a hammer or something of that sort. I used a chunk of steel about 1.5" dia x 3"...allows a lot more finesse than a BFH, but still enough mass to get things done.
Took me over an hour on the first rotor to come up with that and about 5 minutes on the second rotor to get it off.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
TNRocker
Sep 21, 2015 08:36 AM
Mhacker
Sep 12, 2015 07:35 PM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
