spc rear camber kit
Old May 16, 2009 | 10:32 AM
ma2dongpoong's Avatar
spc rear camber kit
i need some answers please??
just brought a spc rear camber kit, i need to know if i still have to swap these toe bolts?
i have a stock suspension with 19x10.5 +17 on rear...
thanks in advance
Old May 16, 2009 | 10:33 AM
Glex25's Avatar
Administrator
thanks in advance
I would do the Toe bolts at the same time.
One less thing to worry about if you decide to drop your car.
Its not necessary for stock height though
Old May 16, 2009 | 11:25 AM
thanks!
Old May 20, 2009 | 03:05 AM
nyckid's Avatar
whats this toe bolt you're talking about? doesn't it come with the spc rear camber kit?
Old May 20, 2009 | 10:25 AM
04G35NYC's Avatar
^ yes, it does.
Old May 20, 2009 | 10:35 AM
EL-EE-ES's Avatar
you dont need the toe bolts to install the rear camber kit, the toe bolt are used on the arm with the spring bucket not on the kit itself.
Old May 20, 2009 | 04:10 PM
MikeGrote's Avatar
i would def get the toe bolt no matter what. cause when you put the rear camber arm on and adjust with it, it messes with the toe of the rear, so you need the toe bolt to correct that. also, for the toe bolt to be useful, you need to make the hole it goes in bigger to allow for more adjustment. the toe bolts come with instructions
Old May 20, 2009 | 04:13 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
why would you get a camber kit if you have the stock suspension???
-GP-
Old May 20, 2009 | 05:36 PM
^ Why???? ummmm because i have 19x10.5 +17 offsets on rear???
yeah the toe bolts came with the kit...
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
