just installed spc-rear camber kit/toe bolt and got alignment, how are my specs?
Old Jun 27, 2009 | 08:51 PM
nyckid's Avatar
Finally got my spc rear camber kit installed with the toe bolts. Got it aligned right afterwards too. Car is dropped on g35 tein s-techs. Can you guys let me know if my specs are okay?
I know the s-techs are suppose to lower the front 1.2" and rear 0.9".
Attached Thumbnails just installed spc-rear camber kit/toe bolt and got alignment, how are my specs?-photo.jpg
Old Jun 27, 2009 | 09:09 PM
Vrod-Mike's Avatar
Looks like you need a front kit. You're way out of spec there.
Old Jun 27, 2009 | 09:36 PM
GreenGoblin's Avatar
The goblin resurrection
Its not that bad I would have like to see the toe a bit better but, its not bad
Old Jun 28, 2009 | 10:48 PM
LaConic2's Avatar
hey did ur kit coem with the SPC camber bolts and toe bolts or u had to buy the them seperately?
Old Jun 29, 2009 | 02:49 AM
SANTOS29's Avatar
I had the same problem as you, my camber settings were out about -1.9 degrees before the installation of the front arms, this is with Eibach prokit.My friend who was doing the alignment recomended I should get the front kit. I ordered it from THmotorsport and I dealt with Eddie amazing guy after I paid for overnight shipping he got the part out of his warehouse that same evening after hours as well, anyway here is the data sheet:
Btw this is with both rear and front alignment kits.
Old Nov 19, 2012 | 11:03 PM
G35DG's Avatar
Nyckid, did u have to elongate the toe bolt area to get your rear camber down to -1.5 on both sides.?
Sorry I know the thread is a few years old.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
