Having a big problems with brakes can someone help please.
Old Jul 9, 2009 | 02:23 PM
djbaselle's Avatar
Brakes Having a big problems with brakes can someone help please.
I have a 2004 G35 COUPE with the bremo package. I Changed my pads for the first time and i can't get my pistons back out i think. because i cant get pressure back to the pedals. I tried bleeding the system from the calipers and only got very little stopping power. Can some one help asap thanks allot.
Old Jul 9, 2009 | 02:32 PM
Jeff92se's Avatar
Red Card Crew
Back out? ie... you pushed them in to give the pads more room to fit? That's a normal procedure but I don't compress them in any more than I have to. Did you purposely push them WAY in?
Front or back?
Old Jul 9, 2009 | 02:46 PM
djbaselle's Avatar
Front. yes i pushed them in just about all the way
Front or back?
Old Jul 9, 2009 | 02:50 PM
Jeff92se's Avatar
Red Card Crew
With what? C-clamp? You didn't unscrew the bleeder when you did this right?
Old Jul 9, 2009 | 03:27 PM
djbaselle's Avatar
No i didnt was i suppose to? yes i used a c clamp
Old Jul 10, 2009 | 11:54 AM
Jeff92se's Avatar
Red Card Crew
No unscrewing the bleeder isn't necessary. I don't see why it wouldn't pop out again once you stepping on the brake. The piston seems to be stuck somehow.
Old Jul 11, 2009 | 12:01 PM
djbaselle's Avatar
anyway to fix this?
Old Jul 13, 2009 | 06:44 PM
ZexGX's Avatar
Couldn't you remove the caliper off the rotor, then push the brake pedal down? The piston should probably slide back out since it no longer has any resistance. Then you can tighten it back down with a C clamp as necessary... The piston should definitely be moving. If it's still stuck inside after you try that, perhaps there's air in the line? It's possible that the caliper might be in need of a rebuild or the piston is damaged, but that's unlikely...
Anyways, if it's still stuck you will have to remove the caliper, and follow the rebuild procedures to pop the piston out using an air compressor (I think that's the typical method).
Frankieg35
Mar 20, 2016 09:42 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
chinee
Aug 8, 2015 10:11 AM
Lsantana757
Jul 20, 2015 09:08 AM
