Suspension question
Old Jul 12, 2009 | 03:45 PM
lerk's Avatar
Suspension question
Due to the fact that not many people visit the suspension section I figured I would ask this question here.
Would 2003 OEM 350z springs fit on a 2003.5 g35 sedan. Would I have to get different struts and shocks or would it be acceptable to run the oem g35 ones with 350z springs?
Thanks
Old Jul 12, 2009 | 04:36 PM
NjMatteSedan's Avatar
They'll work but ur factory shocks in the back won't last that long, you'd have to get 350z shocks or aftermarket ones
Old Jul 12, 2009 | 06:29 PM
RADIOGUY21's Avatar
if you have OEM sport suspension you can swap out the Z springs and use your OEM shocks and struts. The 03-04 Z uses the same spring rates as our sport suspension. If you have non-sport model, you should swap everything.
Old Jul 12, 2009 | 07:29 PM
lerk's Avatar
I believe I have sport suspension because im pretty sure that comes with the aero kit. Thanks a lot guys
Old Jul 12, 2009 | 07:39 PM
mesias's Avatar
Do not go just by exterior trim. Go down the car and check the color of the shocks and struts. If they are red = sport suspension. Still, the best idea is to swap the whole suspension or mix and match compatible dampening rate of shocks with spring rate. Try the sedan FAQ, there is a lot of information there.
Old Jul 12, 2009 | 11:27 PM
junbug's Avatar
Springs will fit with your stock shocks/struts. The 350Z shock/struts are nice cause they're a bit shorter than on the G so it'll gain you back some suspension travel. 05 6MT on Revised 350Z springs/struts.
Old Jul 13, 2009 | 03:36 PM
lerk's Avatar
If i have an 03.5 and my springs are black, im assuming this means its not sport suspension. What would I have to get along with the springs to make the 350z springs fit?
Old Jul 13, 2009 | 03:48 PM
FlyingLumpia's Avatar
If the shocks are Red. You have sport suspension. I would suggest in getting some tokico d specs, they are adjustable and will probably give you the best bang for your buck
Old Jul 13, 2009 | 03:49 PM
ttrank's Avatar
Grocery getter
^+1
Or just go with some low price coilovers.
Old Jul 13, 2009 | 05:03 PM
RADIOGUY21's Avatar
the springs will fit fine, but the Z spring rates are stiffer than what non-sport shocks/struts are designed for. It will result in a choppy unpredictable ride. So if this is the case, I would recommend picking up a full low-mileage revised Z suspension.
Old Jul 13, 2009 | 09:36 PM
lerk's Avatar
Thanks for all the answers
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
