funny shaking ! help!
Old Jul 22, 2009 | 11:07 PM
cmesidewayz's Avatar
hey guys,
is this normal for g's?
every time i go over painted lines in the road, or a small indent, it feels like the suspension vibrates... btw i have an 05 with the upgraded wheels and suspension package.
anyways. its as if the suspension takes the shock, and then rebounds two or three times...
and once i could have sworn i felt the wheel move and the back end slide an inch or two..
do you sort of get the idea of whats happenin?
any ideas?
Old Jul 23, 2009 | 09:56 AM
EL-EE-ES's Avatar
blown shocks maybe?
Old Jul 23, 2009 | 02:47 PM
Terribleone's Avatar
^+1 would be my guess. I had a right front strut that was blowing and it would make the wheel "shake" when I would go over anything.
Old Jul 23, 2009 | 05:36 PM
It has only 18000 miles on it...
if the shock is blown, and i dont take it in to the dealership will it hurt my car at all? at least until i get it checked out?
Old Jul 24, 2009 | 08:49 AM
I dont think it would "hurt" you car per say, but it is going to be super annoying. The only thing i could see it doing is possibly loosening something in the steering or suspension. But I really dont know so I guess that's not supper definitive sorry.
Old Jul 24, 2009 | 11:11 AM
Q45tech's Avatar
Ozone, heat, salt, etc reacts with the rubber suspension bushings causing them to change hardness. Generally a 4-6 year old bushing is nowhere near the parameters of a brand new bushing.
This wear and tear exposure on rubber is why a 4-6 year old car doesn't ride or behave as a brand new one.
Over the past 19.5 years of Infiniti ownership I have replaced many many rubber bushings multiple times as I have gone thru oem + 5 sets of shocks in just 322,000 miles.
Old Jul 28, 2009 | 02:44 AM
The car sits perfect... the gaps are all correct. so if the shock is shot, then wouldnt it sit lower because only the spring is resisting?
Old Jul 28, 2009 | 07:34 AM
EL-EE-ES's Avatar
no...you can test it out by pushing down on the corner of the car. if it bounces multiple time on rebound then there blown or you can look around the shock body for signs of a leak
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Jeff469
Sep 25, 2015 09:28 AM
Fire0nic3
Sep 1, 2015 12:12 PM
miata007
Aug 17, 2015 04:36 PM
ghost_g35
Aug 7, 2015 10:31 AM
