Installed GT Spec STB today
Old Dec 5, 2009 | 08:52 PM
  #46
bigc's Avatar
Wings Nation
28 ft-lbs on a 2005 coupe (see attached). i'd assume its the same for your model year.
Old Dec 5, 2009 | 09:04 PM
  #47
Silencer_0's Avatar
Thanks a lot . Too bad I only have an in-lb torque wrench, guess ill have to go buy a ft-lb one lol.
Old Dec 5, 2009 | 11:03 PM
  #48
bigc's Avatar
Wings Nation
you can get to foot pounds by multiplying by 12. most of the in-lb torque wrenches i've seen go up to 240 in-lbs (20 ft-lbs), so max that out then hand tighten it a bit more.
honestly, you can tighten these bolts without a torque wrench. just don't go crazy and you'll be fine.
Old Dec 5, 2009 | 11:39 PM
  #49
Silencer_0's Avatar
Yeah I thought about using my in-lb wrench, but I think it only goes up to 120 in-lbs....I can just borrow one from my buddy though.
I just kept thinking of the people who snapped the bolts while installing their plenum spacers without a torque wrench haha. But you're right, I shouldn't have a problem with these bolts.
Old Dec 6, 2009 | 12:36 AM
  #50
Silencer_0's Avatar
There seems to be a white clip holding on to the ac lines on the drivers side. Can I just remove it since it's in the way?
Edit: Nevermind, the clip isn't a problem anymore. But there's a brass colored? line on both sides that's in the way....did people just bend it?
Old Dec 6, 2009 | 02:01 AM
  #51
bigc's Avatar
Wings Nation
got a pic? i'm drawing a blank on a brass colored line. IIRC, there should only be one thick and one thin AC line (both aluminum) in that area.
Old Dec 6, 2009 | 03:16 AM
  #52
Silencer_0's Avatar
Finally! Lol
It was the thin AC line that was in the way, but I managed to slip the base of the bar under it. Passenger side was a lot easier to put on. Putting the nuts back on was kinda a pain too since there isn't much room and I was scared of dropping them, lol.
Went for a quick test drive and I can definitely tell the difference, pretty cool! I didn't think the difference would be this noticeable, since most people get it just for looks, but I'm happy with my purchase. Now I can't wait to pick up a set of the Motordyne sways once they're released . Thanks for the help bigc .
EnCr1pt3d
Jul 8, 2019 02:48 PM
Team STILLEN
Aug 10, 2015 08:17 PM
Jussaku
Aug 4, 2015 12:45 PM
