Famous Front Clunk Pop
Aug 3, 2009 | 02:05 PM
I have the clunking noise coming from front suspension!
I RESEARCHED THE WHOLE FORUM
Mods: Tein Basics, Volks GT-C, Ichibia Spacers, Brembo Drilled Rotors.
Action:
1. Replace Lower Transverse Bushing w/ the Whiteline product.
2. Replaced stock Sway End Links with the SPL Adj End Link.
3. I needed new tires and alignment so I got new FK452 and a Alingnment done.
Issue: I still get the CLUNK while turning full radius left and right and when I come to a stop quick.
Also: I know that the COMPRESSION ROD bushing might be causing this too I have not replace them this is the last thing that may be causing this BUT when I get down to check them I feel around and they look perfectly fine.
This is a pain If any of you fellow owners can please give me some advise.
Reply 0
Aug 3, 2009 | 07:54 PM
I am having the same issue when I make a left turn... shop said everything looks solid and "could be" the compression rods....
Reply 0
Aug 4, 2009 | 03:06 AM
are the springs snug or loose when the car jacked up?
Reply 0
Aug 4, 2009 | 01:32 PM
They are snug not loose I gave them a tug and they are tight.
Reply 0
Aug 6, 2009 | 01:40 PM
I have the same pop on full turn of the wheel to the left. Dealership said it was my strut mount. I have 350z struts and ichiba sprints.
Reply 0
Aug 7, 2009 | 05:40 PM
Clunk
What is wrong with the Strut mount is it broken, wear and tear etc Ive read on the forum some guys usually re-tighten the Strut mount and it goes away.
Quote: I have the same pop on full turn of the wheel to the left. Dealership said it was my strut mount. I have 350z struts and ichiba sprints.
Reply 0
Aug 7, 2009 | 05:52 PM
I just started having this unsuak clunking noise from the front left side when I turn or stop quick aswell.
Reply 0
Aug 7, 2009 | 07:45 PM
Reply 0
Mar 8, 2010 | 11:02 AM
Can anyone share any more stories on this? I got this "clunk" noise about a month ago when I make a full right turn. I can hear it coming from my driver side front area.
Reply 0
