Another brake related problem!!!
Old 08-15-2009 | 08:14 PM
blownvert's Avatar
i thought getting new pads and replacing that bad pad that had a broken clip would fix it. the noise is coming i think from the right front. its like a sqeaking, cricket sound. its like a tapping non stop sound when im going like 30 and if i press the brakes normal it will go away. if i tap like slightly and hold it in that position slightly then i can really hear that cricket tapping sound. its very weird.
Old 08-17-2009 | 07:55 PM
blownvert's Avatar
bumppp
Old 08-17-2009 | 11:26 PM
blownvert's Avatar
it even does it at 10mph. it makes a noise everytime the wheel turns, if i tape the brake lightly and hold it i can hear the brake linkage or something squeak and make a fast tapping sound. if i hold down the brake harder going faster the noise will go away. what is it the caliper? its something in there on the front right side
Old 08-17-2009 | 11:44 PM
geew1z's Avatar
does the sound change if u turn the wheel and hit the gas?
Old 08-17-2009 | 11:55 PM
DaveB's Avatar
How old are the rotors? Consider this if the rotors have more than 15K miles:
https://g35driver.com/forums/brakes-...ke-squeal.html
Old 08-17-2009 | 11:58 PM
JAYY-G35's Avatar
i have the same symptoms
Old 08-18-2009 | 06:53 AM
STCLAIRWEST's Avatar
I got the EXACT same symptoms can somebody help? It only does it 5 mins after driving and doesn't happen when it rains. I thought the problem would go away after I changed the pads and rotors but it didn't work.
Old 08-18-2009 | 10:07 AM
blownvert's Avatar
i have got brand new rotors and pads if you guys read my last thread for the wheel shaking and clips broke off. I thought the noise was related to that brake pad wear indicator. the clip/spring clips into the loop, but its not. Its a very annoying sound as the wheel turns you can hear like a squeak in the motion like every half second as the wheel makes its round. if i slightly press brake pads and hold it not like hard i can hear the sound like a wiggling cricket sound that is tapping very fast.
Old 08-18-2009 | 10:46 AM
junbug's Avatar
Is it possible the dust shield was accidentally bent and is touching the rotor?
Old 08-18-2009 | 10:57 AM
blownvert's Avatar
ya but if i press the brakes hard the noise will go away while in motion. if i press the brakes lightly and hold i have this squeaky tapping sound very rapidly. its gotta be somewhere on that caliper area.
Old 08-20-2009 | 10:34 AM
blownvert's Avatar
bumppppp
Old 08-21-2009 | 01:32 PM
G35fromPA's Avatar
Are the shims installed?
Might need to take apart the caliper to see if anything is sticking. Could be dust seals/boots
Old 08-21-2009 | 05:43 PM
RacingBrake's Avatar
Have you tried taking it to the dealer for warranty work?
There was a CNN article about a Lamborghini Gallardo owner who had a similar problem. The state ended up deciding in his favor and declared his Lambo a lemon and they were forced to buy it back. lol.
Old 08-22-2009 | 11:54 AM
Gilley's Avatar
Make sure the original shims are on the pads.
Old 08-24-2009 | 12:26 PM
blownvert's Avatar
i dont know i didnt install the pads there brand new, but i now think its coming from the rear right brakes. i just recently got brand new rotors and pads for the rear 6 months ago. everything is breaking
Quick Reply: Another brake related problem!!!
