lower control arm help
Old Aug 20, 2009 | 06:48 PM
mcaron's Avatar
Hey guys im in need of a lower control arm and/or a "knuckle". Im curious if a other nissan vehicles lower control arm or knucle would fit on my 2004 g35x.
Can anyone help me out and tell me if a lower control arm off other nissan cars would fit? It would make it much easier to find at some local junkyard.
Thank you guys
Old Aug 20, 2009 | 07:54 PM
OCG35's Avatar
you're referring to the transverse link (in the FSM) right?... are you sure you need the whole arm or just the bushing? I just bought Nismo bushings from Performance Nissan (mynismo) $40 each (the inside bushing): http://www.mynismo.com/cart/
… Z1 has Whiteline bushings (inside and outside): http://www.z1auto.com/prodmore.asp?m...ng&prodid=3783
Old Aug 20, 2009 | 07:59 PM
mcaron's Avatar
no i need the whole lwoer control arm. its # 13 in this picture
Old Aug 20, 2009 | 08:09 PM
OCG35's Avatar
oh... rear suspension - sorry...
Here:
http://www.trademotion.com/partlocat...layCatalogid=0
Old Aug 20, 2009 | 08:12 PM
mcaron's Avatar
yes ty, but im going to find one at a local junkyard. What i was wondering, would a lower arm off, lets say a maxima or altima or 350 fit? just so it would be easier to find that a g35
Old Aug 20, 2009 | 08:16 PM
OCG35's Avatar
use the drill down in the link I provided and cross reference the part numbers... if they are the same as any of the other cars you have access to then yes.
Edit - I just realized the drill down menu doesnt provide part numbers... call them and see if the part numbersare the same.
Performance Nissan: 626-305-3000
Old Aug 20, 2009 | 08:17 PM
mcaron's Avatar
ok ill give that a try, thank you very much
Old Aug 20, 2009 | 08:26 PM
mcaron's Avatar
ok yea i was like freaking out trying to find the part number haha ill give them a call tomarrow, thank you
Old Aug 20, 2009 | 08:30 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
That would be called the Spring Bucket. You can use a spring bucket off of a 350Z, it's all the same.
-GP-
Old Aug 20, 2009 | 08:31 PM
mcaron's Avatar
kk thats what i was told, hopfully i can find one localy
Old Aug 21, 2009 | 08:10 AM
Mustang5L5's Avatar
only the 350Z. everything else in nissans lineup is FWD, so different suspension
Old Aug 21, 2009 | 08:57 AM
mcaron's Avatar
ok thank you, thats what i was thinking as well, just wanted to be sure
Old Aug 21, 2009 | 04:56 PM
Tollboothwilley's Avatar
+1. 350Z uses the same rear spring bucket/lower control arm.
Old Aug 21, 2009 | 04:58 PM
Jeff92se's Avatar
Red Card Crew
Also if you need to replace one of those, I'd have it checked for other suspension damage also.
Alex Koss
Oct 29, 2021 12:53 PM
rezendvous420
May 31, 2020 01:26 PM
nineiron
Sep 10, 2015 12:08 PM
nineiron
Aug 19, 2015 12:45 AM
erickLA
Aug 18, 2015 04:46 AM
