Problem: Left wheel is more tucked in than the right (picture)
Old Aug 27, 2009 | 11:18 AM
iamericgee's Avatar
dude i have this same problem my driver side is lower than the passenger side i always thought it was because of the gas tank
Old Aug 27, 2009 | 11:25 AM
JOKER's Avatar
CLUB MODERATOR
could be also because majority of the time you are the only passenger in the car.
So driver side springs and shocks wear out before the passenger side.
So if interested you can swap springs between left and right side to make the wear more even.
Old Aug 27, 2009 | 11:41 AM
frozenmango's Avatar
joker, if my axle is shifted an alignment would not help it would it?
Old Aug 27, 2009 | 11:59 AM
JOKER's Avatar
CLUB MODERATOR
I don't think that alignment would even show that it's shifted.
I'm not sure if it's even possible to shift the axle.
Most likely it's your spacers rather then axle.
Old Aug 27, 2009 | 06:47 PM
my spacers are fine and correct all around...like i said, it was noticably tucked even before i added the spacers and drop.
heres before drop and spacers
Old Aug 27, 2009 | 07:31 PM
JOKER's Avatar
CLUB MODERATOR
another thing you can do is take the spacer and the wheel from the right side and switch it with the left. See if it changes anything.
Old Aug 27, 2009 | 07:45 PM
dude im telling u its not the spacers lol. look at that picture. that pic was taken BEFORE the spacers
Old Aug 27, 2009 | 08:25 PM
should i get an alignment first or camber kit then alignment? or just alignment?
Old Aug 27, 2009 | 09:48 PM
JuicedAthletics's Avatar
You sure your bumper isnt a little crooked?
Old Aug 27, 2009 | 10:02 PM
JOKER's Avatar
CLUB MODERATOR
that's why I said change the wheel too.
Could be the wheel. You got to rule out one thing at a time.
Old Aug 27, 2009 | 10:03 PM
when i first got the car it was even steven...
Old Sep 1, 2009 | 10:51 PM
mesias's Avatar
This is what I would check:
1. If the off sets of the wheels are correct.
2. If the rear springs are identical
3. if the body is shifted due to a crash
Old Sep 2, 2009 | 12:30 AM
DaveB's Avatar
Get an alignment for Christ's sakes. The driver's side could be toed out and with less camber and the passenger side could be really toed in with a bit more camber. All that would definitely explain the cause of your problem.
Old Jul 17, 2010 | 09:43 AM
got an alignment.
front cam 2.4/2.5
rear cam 3.1/3.0
front toe was off, rear was in spec
passenger front caster off
Old Jul 17, 2010 | 12:38 PM
  #30
jrhykushi's Avatar
soooo does your problem still exist?
