Problem: Left wheel is more tucked in than the right (picture)
Old Aug 26, 2009 | 11:12 AM
frozenmango's Avatar
Im dropped on s-techs with 25 mm spacers. But even before the drop the left wheel was more noticably tucked than the right. however, when i first got the car it was pretty even. what could be the problem?
car just hit 50k. noticed the difference at 45k. dropped installed at 48k.
Old Aug 26, 2009 | 04:12 PM
LightsOut's Avatar
SIETESG
did you ever get an alignment?
Old Aug 26, 2009 | 07:02 PM
nghiars's Avatar
alignment? and make sure the springs on set on right.
Old Aug 26, 2009 | 08:04 PM
bigc's Avatar
Wings Nation
could just be the angle of the pic (which, honestly, looks pretty dead on even), but it does look like your driver's side quarterpanel and rear bumper are flared out more.
Old Aug 26, 2009 | 08:23 PM
its def not the angle of the pic. and i never got an alignment...
do our bearings go bad? does this happens when ball bearings go?
Old Aug 26, 2009 | 08:33 PM
varelis617's Avatar
If a bearing went the sag wouldnt be that noticeable if at all. I would check the boot of the spring and see if its bent or twisted somehow or maybe the spring itself is bent. Also did you cut the springs at all?
Old Aug 26, 2009 | 09:00 PM
LightsOut's Avatar
SIETESG
get an alignment
Old Aug 26, 2009 | 09:15 PM
like i said, it was like this even before the drop. its not the springs
Old Aug 26, 2009 | 09:38 PM
LightsOut's Avatar
SIETESG
maybe you have a wheel spacer and dont even know it...
guessing
Old Aug 26, 2009 | 09:51 PM
varelis617's Avatar
Question
Ok then it could be the boot that holds the bottom of the spring to the chassis.
Old Aug 26, 2009 | 10:25 PM
guessing
like i said, im running 25mm spacers...
Old Aug 27, 2009 | 10:21 AM
what could be wrong with it? how could i diagnose?
Old Aug 27, 2009 | 10:31 AM
djamps's Avatar
Maybe the bumper is a little out of shape. If you get an alignment and it all checks out then it's ur body not the suspension.
Old Aug 27, 2009 | 11:06 AM
JOKER's Avatar
CLUB MODERATOR
Park a car on a level ground.
Put a level on the trunk to make sure car is leveled
Something like this (little longer would actually be more accurate)
If the car is not leveled take a measuring tape and measure the rear from the ground to the top of the wheel well. If your distance is different then you know that one spring is lower/higher.
If everything is leveled then take a heavy nut (or just something heavy) and tie it to a piece of string (long enough to go from the top of the wheel well to the ground, but not touching the ground)
Tape the string to the flat part of the wheel well and let the string settle.
so it looks something like this
(A) is the correct way to do it.
Once it stopped swinging carefully measure the distance between the string and the center of the wheel. Do that on both sides and you'll determine if your axle is shifted or if one of your spacer is bigger then the other.
Old Aug 27, 2009 | 11:15 AM
JOKER's Avatar
CLUB MODERATOR
oh and make sure your tires are equal pressure when you doing that.
