Hubcentric Spacers or the bolt on spacers?
Old Aug 28, 2009 | 10:44 PM
TurboDreamzG's Avatar
What up guys, I'm looking into getting some spacers and saw that have the kind with the studs included and then the ones that bolt straight on. I was told if i have the recessed area behind my wheels that I could go with the bolt ons....here are some pics, help would be appreciated.
By the way they are Front: 245/35/19x8.5 +20mm and Rear: 285/35/19x9.5 +25mm
Also I was told to go with 20mm spacers all around to achieve the closest to being "flush" as possible, what do you guys think?
Old Aug 29, 2009 | 12:07 AM
Boston's Avatar
Your current wheels will work with spacers that have the studs built in. As for 20mm all around, that will give you a 0 offset up front and +5 in the back. It's doable but your going to have additional negative camber.
Old Aug 29, 2009 | 12:18 AM
Calvin's Avatar
Overglorified Altima
You can have both...bolt on hub centric spacers come in 15mm, 20mm, and 25mm.
Old Aug 29, 2009 | 04:34 PM
yeah but what size you think would be best for my car?
Old Aug 31, 2009 | 08:55 AM
reverse's Avatar
i have same setup with my 5zigens. i run 20mm kics all the way around at +5 now.
20mm is good, but you might be able to run 25 in the rear but you will rub the fender.
Old Aug 31, 2009 | 03:41 PM
LightsOut's Avatar
SIETESG
I say 10 front 15 rear
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
the93owner
Oct 4, 2015 09:40 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
