poor handling.. from spring install?
Old Sep 9, 2009 | 09:01 AM
DanielsG's Avatar
Hey guys. Last week i installed my Eibach sportlines. the install was easy and took me about 4 hours. (including rear camber kit) As i began to drive the car it felt pretty good but once i took it on the highway it felt dangerous. It has now been about a week and the car feels even worse. at first i though it could be that the alignment is way out of spec but then it felt so bad that i didnt think it could be that. If im on the highway and i try to keep it straight by correcting the steering it feel as if the car keeps going in that direction forcfully. If i try to counter that, it jets in the other direction leaving me feeling like im going to lose control. Could it be that the alignment is that out of spec that it is making the car feel this bad? any input will help Thanks
Old Sep 9, 2009 | 09:08 AM
Glex25's Avatar
Administrator
Definitely sounds like alignment to me
Old Sep 9, 2009 | 10:11 AM
DanielsG's Avatar
thats what i thought but wow i didnt think it would be that bad. I guess its really thrown out of spec... i still want to wait another week until i go for an alignment.
Old Sep 9, 2009 | 10:36 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'm sure it's off, but it shouldn't have been that much of a difference.
Especially if you notice it getting worse.
What are your tire pressures like?
Have you dble checked the install?
Old Sep 9, 2009 | 10:47 AM
jwrape's Avatar
That sound like alignment... I would defintately get that done
Old Sep 9, 2009 | 12:11 PM
DEEZBLUBALLZ's Avatar
++10,000........get an alignment. You go straight to an alignment shop, after an install like that. immediately!
Old Sep 9, 2009 | 12:19 PM
LightsOut's Avatar
SIETESG
double check your work
Old Sep 9, 2009 | 12:24 PM
elayman's Avatar
you can't get the camber arms back to the exact place they were without a machine, and maybe you forgot to lengthen them so they were the same length as the stock ones? idk
DEMoLITIoN's Avatar
sportlines give you an aggressive drop. did you remember to torque everything to spec?.
Old Sep 9, 2009 | 02:31 PM
DanielsG's Avatar
I torques everything good. I think it's the algnment
Old Sep 9, 2009 | 04:53 PM
redlude97's Avatar
your toe is probably way out of wack
Old Sep 9, 2009 | 05:17 PM
Locksmith's Avatar
Check your toe and camber, both are probably way off.
Old Sep 9, 2009 | 08:31 PM
DanielsG's Avatar
its gotta be that. I just checked everything and my works looks good. I can visually tell that the tow and camber are way off. the car feels like im driving a truck down the highway when its windy... back and forth back and forth..... im going to wait a few more days and then go for the alignment just so the springs settle.
Old Sep 9, 2009 | 08:45 PM
nghiars's Avatar
your toes and camber are prob out of whack... drriver side wheel pulling to the left while passenger pulls to the right will make your car very unstable. I would wait 2 weeks after the install to align it.
Old Sep 12, 2009 | 01:58 PM
| 1cleanG |'s Avatar
if you knew you needed a camber kit, how did you know how to USE the camber kit and put it into spec? Toes, alignment, camber....how did you adjust them?? You 100% need to take it to a suspension shop.
