Need Help: Piston Removal from Caliper
Old Sep 16, 2009 | 11:24 AM
G35fromTO's Avatar
I'm planning on overhauling the calipers; I want to do it myself as everything seems pretty straightforward. The only thing I'm questioning is how to get the piston out of the caliper so I can replace the seals, clean it up, and so on... according to the FSM (http://www.nicoclub.com/FSM/G35/Sedan/2003/br.pdf page 36), you need to use compressed air to get it out. I don't have that at home so is there any other way of doing this(I'm open to creative ideas!)? Any help would be greatly appreciated.
Old Sep 21, 2009 | 01:38 PM
lightspeed1's Avatar
You can put the caliper in a vise, and pull the caliper out with twisting motion held by an adjustable wrench. Put a towel thick cloth material between the wrenchand piston so you dont mess it up. That what i did. i m currenlty looking to replace the pistons on my brembos but dont where to find them. The ones I have a re good but since i replacing everything anyway why not new pistons. (04 brembos, powercoated, with new seals). Let me know if you fnd anywhere i can find the piston and what size they are.
Old Nov 11, 2009 | 10:05 PM
G35fromTO's Avatar
So I ended up taking apart one of the calipers. I used a bicycle floor pump instead of compressor and it worked like a charm. My pump came with a little nozzle attachment for inflating ***** and it was a perfect match for the caliper; the piston just shot out without too much effort. Just thought I'd update this in case anyone needs to do the same thing in the future.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
