Picture request : g35 coupe on eibach prokit/tein stech/tanabe nf210
Old Sep 8, 2012 | 07:27 AM
  #136
SUMATIC's Avatar
Originally Posted by tylerxfire
^^agreed...that stance looks messed up...rear looks quite a bit lower than the front for some reason..id say the rear mount was either left out or cut too much?
yeah i agree with these guys. the fronts look a lil higher than the rears. you should def try to take out everything in the trunk and see. but i dont think itll make that much of a difference.
its pretty noticeable.
Old Oct 16, 2012 | 09:35 PM
  #137
cowboys13's Avatar
Does anyone know what I can do to drop the front a little more? Cut the spring?
Old Nov 28, 2012 | 11:54 PM
  #138
ItsA..Gthing's Avatar
Dont cut the spring^^^^did you take stuff out of the trunk? pics?
Old Jun 17, 2013 | 01:42 AM
  #139
Ttt
Old Jun 24, 2013 | 08:02 PM
  #140
JKL1031's Avatar
Will I need a front camber kit with a pro kit or similar?
Old Jun 24, 2013 | 08:07 PM
  #141
saywat?'s Avatar
ima say no from my experience. but i dont drive much. i drive everyday jus not many miles but my tires are fine esp the front. the rear is the one u gotta worry about imo. i have some camber wear but its expected. its jus not excessive
Old Jun 24, 2013 | 08:44 PM
  #142
cowboys13's Avatar
Agree with saywat?. If you drive on the highway a lot then you will need a camber kit for sure unless you dont mind buying tires every 5 or 6 months.
Old Jun 24, 2013 | 09:40 PM
  #143
No,you don't need it..One inch drop and my alignment is in the green..Get a rear one atleast to dial in camber and toe...
Old May 27, 2014 | 01:43 PM
  #144
EM04_g35's Avatar
Eibach prokit g35 or 350z for my coupe?
Hi guys, new here I would really like to know which springs I should go with I want no wheel gap but just the perfect drop all around, I'm going to be putting on str607 wheels in the future and would like no rubbing issues... My car is an 04 coupe 18" OEM wheels. Thanks in advance.
Old May 27, 2014 | 02:21 PM
  #145
ScraggleRock's Avatar
No wheel gap and no rubbing? Sweet.
Old Jun 12, 2014 | 12:29 AM
  #146
EM04_g35's Avatar
If possible lol.. I'm thinking the eibach prokit for the G would be best since I will be going with 19" wheels? Then after that get an alignment see if specs are close to stock.
Old Oct 22, 2014 | 06:54 PM
  #147
privatecorye's Avatar
Originally Posted by vegaseric
Tein S-Techs
What are your tire specs? I have 225/50/17 F and 245/50/17 R, and I'm scared that if I install these springs I will have to camber, I was going to downsize to 40 would I have a nice drop not too low and will it fit without camber? And these are the 1.2 inch springs right?
laksjd84
Jul 24, 2015 05:12 PM
BlackGee35
Jul 23, 2015 01:36 PM
driftsucky
Jul 15, 2015 12:38 PM
