Picture request : g35 coupe on eibach prokit/tein stech/tanabe nf210
Old May 30, 2012 | 06:10 PM
  #106
sportsmanG35's Avatar
got a set of tanabe df210's on my sedan. i personally think the drop is perfect. I was thinking of it being too low but once installed it's perfect for daily driving.
Old Jul 9, 2012 | 06:27 PM
  #107
leetillman351's Avatar
do 350z prokits rub on 19s on the g35c? reviving the thread!!!
Old Jul 9, 2012 | 06:40 PM
  #108
antodiaz's Avatar
not at all. I had them with 25mm spacers all around absolutely no rubbing.
Old Jul 9, 2012 | 06:57 PM
  #109
thank you, how was the ride quality? I'm on the highway quite a bit.
Old Jul 9, 2012 | 07:01 PM
  #110
antodiaz's Avatar
well on mine it was really close to factory settings, obviously more stable.
Old Jul 9, 2012 | 07:37 PM
  #111
What do you mean on yours..? Did you do anything else to make it smoother?
Old Jul 9, 2012 | 07:40 PM
  #112
antodiaz's Avatar
I have a G35 coupe but is not lowered anymore because Im selling. I had 350z's pro-kit, 25mm spacers all around and rear camber kit with toe bolt.
Old Jul 9, 2012 | 07:50 PM
  #113
Did you need front camber kit or could you get it back to spec?
Old Jul 9, 2012 | 07:52 PM
  #114
antodiaz's Avatar
It had a little bit of negative camber but not enough to wear the tires on the inside.
Old Jul 9, 2012 | 08:09 PM
  #115
Around 2 degrees or what, cause im on megans right now and it ended up being about a 2 1/2 inch drop and its about 3 degrees of neg camber
Old Jul 9, 2012 | 08:11 PM
  #116
antodiaz's Avatar
I don't remember the exact number and don't even know what I did with the spec sheet.
Old Jul 10, 2012 | 12:56 AM
  #117
ok, thank a lot man. appreciate the help. gonna get some next week!
Old Jul 12, 2012 | 02:46 AM
  #118
gareth32295's Avatar
hi
I'm new to the whole lowering thing. i have a 2003 g35 coupe 6mt with the oem 19in wheels and navi. i really like the way the eibach prokit looks. i want to put the kurums z front on my car. i want to lower the car about 1/2 an inch to an inch. is that too low for that front bumper. should i go with the g35 prokit or the 350z prokit? will i need a camber kit, if so which one? will i need to role my finders? allot of people on the tread are talking about spacers, what are spacers and do i need them?
thanks for the help, any input is helpful
Old Jul 13, 2012 | 08:24 PM
  #119
sharkcityG's Avatar
quick question i just got my pro-kits installed and the front wheel gap is still there it probably dropped half an inch o_0 what should i do
Old Jul 16, 2012 | 01:53 AM
  #120
antodiaz's Avatar
Give it like a week. Once they settled is gonna be lower.
