Eibach prokits and eibach rear camber kit, had them on for about 4 months now and loving them. And yes i know i need spacers! Also no specs but will be a little negative i think.
Just switched to coilovers, so I have a set of NF210s of anybody is interested. Gonna post pics tonight or tomorrow and have them in the marketplace.
Quote:
Here's another !
Do you have the G35 or 350z prokit? Any mount for the springs?Originally Posted by cowboys13
Here's another !
G35 kit, and have no idea what the mount for the springs is. Can you please explain what that is and its purpose, thanks!
Quote:
Is a rubber mount that holds the top of the rear springs. Some people including me when I had my coupe will cut it so you can lower the back a little more with springs. I had 350z's pro-kit on mine and the rear was higher than the front so I cut it 1/2 an inch and got a even drop.Originally Posted by cowboys13
Thanks antodiaz!!
Also, Cowboys13, it looks like you have the OEM 19" Rays Engineering rims? Do you have spacers? If so, what size?
Thanks!!
Thanks!!
Quote:
Here's another !
is it just me or does it look like you have a reverse rake...front higher than back. did you buy car used? wonder if someone modded spring mount. back looks really low for either G or Z Prokit. possibly big stereo in the trunk?Originally Posted by cowboys13
Here's another !
tylerxfire
close
- Join DateJul 2008
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:56 Times in 49 Posts
^^agreed...that stance looks messed up...rear looks quite a bit lower than the front for some reason..id say the rear mount was either left out or cut too much?
For the people that are using pro-kits, how long have you been running on them and did you experiance any shock damage ?. tnx
Thanks!!
Yes OEM 19's, but no spacers. My wheels are sunked in and I definitely need spacers.Originally Posted by Sals G35 Coupe
Thanks antodiaz!!Also, Cowboys13, it looks like you have the OEM 19" Rays Engineering rims? Do you have spacers? If so, what size?
Thanks!!
Quote:
Hmm, it might be the ten inch subwoofer, amp, spare wheel, jack, and cleaning supplies?? I haven't checked to see if taking all that sh_t out would make a difference. I'll try and let you guys know.Originally Posted by DRG35R
Quote:
Let's see your stance!Originally Posted by tylerxfire
Quote:
I've had mine for over half a year now and haven't had any shock damage.. I'm using stock shocks btw. Also make sure you get a camber kit if decide to go with.the pro-kits.Originally Posted by sharkcityG
