brake pads and tires... which ones?
Old Oct 19, 2009 | 06:41 PM
GTree5Sedan's Avatar
hey guys... just wanted to know what brake pads to get for the front. I need to replace them and bought the car in July. I wanted to get hawk hps pads since I hear OEM sucks *****. However, I heard the hawk hps pads break in the winter.
I also need some winter tires, is used ones any good if tread is still good? cause i dont want to spend like 500-700 on new ones. Any good quality winter tire brands for our cars RWD should be difficult in the winter.
Thanks...
Old Oct 19, 2009 | 06:50 PM
JBaildon's Avatar
I really like axxis pads, check them out. Very little dust, good bite and durability.
Old Oct 19, 2009 | 08:06 PM
OCG35's Avatar
Thanks...
OEM pads are actually very good. They just dust like crazy... I've used Hawk HPS and OEM - and the OEM function way better - but the Hawk dust less... since you are looking for a winter setup and being in Canada, I doubt you care about dust... so I would suggest OEM.
I live in So Cal, so would be of no use recommending "winter" tires.
Old Oct 19, 2009 | 09:27 PM
ttrank's Avatar
Grocery getter
03/04 OEM pads are good but they also don't last long and eat rotors for lunch. If you have an 05/06 you are better off since you have the larger brakes.
Like Mike said, the Hawk HPS pads are not quite as good as the oem. The last longer and are a bit more fade resistant but for normal cold weather driving the oem pads are better.
Old Oct 19, 2009 | 09:30 PM
Kris79's Avatar
battle froggy
03-04 endless vita neova very little dust no noise very good bite and do not chew up your rotors. 05+ oem
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
