modifying spc a-arms
Old Jan 14, 2010 | 01:23 PM
erklep's Avatar
im looking for the opinion of someone with knowledge in metal fabrication or engineering... i have a concern with the strength of my a-arms after modifying them. im looking to pull a little more pos camber up front and everyone knows, the spc a-arms dont have much adjustment. my question is, how much can i grind out (of the circled section,pictured below) before sacrificing the safety of the arms? im sure i could completly grind that whole section out but IF the ball joint nut happened to work itself loose one day, id be in some trouble. i also thought about cutting it completly out and having that section extended out a little bit. that would then require a bit of persuasion from underneath too since i would be hitting.
Old Jan 14, 2010 | 01:27 PM
Calvin's Avatar
Overglorified Altima
If you use the provided spacers, SPC a-arms have the MOST positive adjustment....+3 degrees IIRC. The spacers add a static +2 degrees. The arms themselves can adjust up to +1 degree.
Old Jan 14, 2010 | 01:33 PM
G35Papa's Avatar
^What he said. Just add the spacers and you shouldn't need to hack the arms
Old Jan 14, 2010 | 01:34 PM
erklep's Avatar
thats my problem. ive been trying to get ahold of the spacers. i purchased the arms used from a member on here about a year ago and the spacers were not included. i found one member who has the spacers available but he will not ship them.
Old Jan 14, 2010 | 01:37 PM
Marinelli Motorsports's Avatar
Just keep looking for the spacers is your best bet... I have contacted SPC too see if they would sell just the spacers by themselves and they won't
Old Jan 14, 2010 | 01:39 PM
HenryLee's Avatar
I think I may have some.
Old Jan 14, 2010 | 01:41 PM
erklep's Avatar
me too they said they recc. i install their adjustable ball joints for added adjustment if i dont have the shims
Old Jan 14, 2010 | 01:42 PM
erklep's Avatar
please take a look for me. PM me your price shipped to 08081.
Old Jan 20, 2010 | 03:09 PM
erklep's Avatar
anybody come across the shims? really need these asap
Old Mar 4, 2010 | 10:22 PM
erklep's Avatar
still looking for a set of shims! need them for spring
Old Mar 4, 2010 | 10:49 PM
AARONHL's Avatar
How much where you looking to spend for my unopened spacers?
Old Mar 4, 2010 | 10:50 PM
erklep's Avatar
no idea what theyre worth. pm me with a price if you wanna get rid of them
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Sep 16, 2015 05:33 AM
