SPC toe bolt use for rear camber ?
Old Jan 19, 2010 | 10:13 PM
bsowhat1's Avatar
According to SPC, the toe bolts can also be used in to replace the OEM rear camber bolts. Has anyone tried this instead of buying rear camber arms?
Old Jan 19, 2010 | 10:22 PM
GLuXuRy's Avatar
never tried it .. but you still might have to e-longate the hole for more adjustment .. honestly the arm is easier to install and only cost 140 bucks for the pair
Old Jan 20, 2010 | 06:53 AM
bsowhat1's Avatar
Yes you would elongate the hole. Cost $44 for a pair of bolts. A lot cheaper than camber arms. Lighter too. Just wondering if anyone has done it.
Old Jan 20, 2010 | 06:36 PM
bsowhat1's Avatar
You misunderstand. There is a rear factory camber bolt in addition to the toe bolt. I am asking if anyone has installed an SPC bolt in the camber position.
Old Jan 20, 2010 | 06:56 PM
G35Papa's Avatar
You can do it, it will fit, they will work but only be affective if you elongate the holes.
I think what metaldrummer is saying, once you elongate the hole for the camber bolts, you might not have enough spec with the OEM toe bolts to get your toe back into spec. So you would need to elongate the toe bolts as well.
Old Jan 20, 2010 | 08:36 PM
bsowhat1's Avatar
I would do both toe and camber bolts. The point is to save some money over camber arms and save a little weight too since the SPC camber arms are pretty beefy.
Old Jan 21, 2010 | 01:06 AM
GLuXuRy's Avatar
lol your not gonna notice a damn thing with a few onces
EPG35
Aug 16, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
