Stiffer spings on coilovers / 12k - 10k feedback
Old Mar 2, 2010 | 03:00 PM
Glex25's Avatar
Administrator
Originally Posted by AidanP
The roads here aren't flawless, but I'm willing to live with a stiff ride for greater overall handling. I'd like the least possible body roll with the best steering response. In your honest opinion Glex, would you recommend that I go 14/12?
I would recommend 12/10 for the average user looking for less body roll and better handling.
Old Mar 2, 2010 | 03:03 PM
Deezflip's Avatar
Originally Posted by Glex25
200mm is the standard
180mm is the shorter version
You can barely see the numbers here
^ These were the standard set bought from a vendor
10/8 as designated by the last numbers on the springs
^ These were a upgraded (Stiffer 10/12 as designated by the last numbers on the spring) set that I had purchased for the standard set
before opting to just buy a new set with revalved shocks and 14/12 spring rate
Number breakdown
62 = diameter
200 = length
12 = spring rate
If i'm not mistaken, those were the old design where it had a gold collar where the 200mm and 180mm springs were shorter to compensate the space of that gold collar. The newer 230mm and the new "shorter" 210mm are the fatter ones that uses oem factory rubber support in the spring bucket. If i'm not mistaken the gold collar was taken out for the clunking issues.
Originally Posted by Black Guy
Here is the difference gentlemen. Old design vs new design
Old Mar 2, 2010 | 03:24 PM
Glex25's Avatar
Administrator
^ I had forgotten they went with a new design on the springs to do away with the gold bucket even though i never had such clunking issues
I'm using their new ER Type Coilvoers that have the external reservoir that still uses the spring bucket.
Old Mar 2, 2010 | 04:13 PM
Johnnyone's Avatar
Appreciate it guys. This is the type of feedback i was looking for.
Sounds like 10k / 8k would suit my needs.
Appreciate the info on the shorter spring. Didn't realize that option was avaliable.
Old Mar 2, 2010 | 04:15 PM
AidanP's Avatar
Glex, is the handling improvement between the 12/10 and 14/12 noticeable?
Old Mar 2, 2010 | 04:25 PM
Glex25's Avatar
Administrator
I never bothered with the 12/10 setup I sold those awhile back to another member who hardly post.
I just went straight to 14/12 with the re valved shocks
with my re valved shocks i can go 12/10 or 16/14 if I wanted.
You can't go from 10/8 to 14/12 without re valving the shocks
you can go from 10/8 to 12/10 or even to 8/6 if you want but you can't
go more than -/+ 2k without re valving.
Old Mar 2, 2010 | 04:28 PM
AidanP's Avatar
I'd read that on the BC Racing website. I just wanted to confirm that the handling improvement between 10/8 is and 14/12 is noticeable and worthwhile (subjective) to you?
Old Mar 2, 2010 | 04:36 PM
Glex25's Avatar
Administrator
It definitely was
Old Mar 2, 2010 | 04:42 PM
ShanesG's Avatar
Are you planning on scraping rim or something??? Not sure why the stiffer spring rate is needed.......
Old Mar 2, 2010 | 04:45 PM
Glex25's Avatar
Administrator
I was doing a few autox where there were some large dips and I would bottom out, some road courses too that's why I opted for the stiffer setup so the car wouldn't dip in those conditions or under hard braking
Old Mar 2, 2010 | 04:49 PM
ShanesG's Avatar
^I meant for the OP, he stated he's not gonna track it...
Old Mar 2, 2010 | 04:59 PM
Johnnyone's Avatar
Wasn't planning on scraping the rim... just didn't know if i needed them for a semi aggressive setup.
Old Mar 2, 2010 | 05:02 PM
ShanesG's Avatar
You dont need them!!!
Unless you are dumped and run the risk of hitting your wheel lip on the fender or inside of the fender.
Old Mar 2, 2010 | 05:09 PM
AidanP's Avatar
I'm looking for the best handling with the least body roll. From what Glex has said, it seems like the 14/12 would be worthwhile. The Tein flex are 14/14, so I don't think that BC's with 14/12 are unduly stiff as compared to other performance oriented setups out there. Am I wrong?
Old Mar 2, 2010 | 05:11 PM
  #30
Johnnyone's Avatar
Trying to get my fitment from this
To this
Had to borrow your pic there Dre, hope you don't mind.
