--------Problems with new Suspension.. "VDC Off" " SLIP".. HELP.---------
okay.. i am having problems with my suspension.. this is what i had installed yesterday..
i had the HKS Hypermax III non-sport coilovers installed
SPL front camber arms
SPL rear camber arms
SPC toe bolts..
the car is pretty slammed.. i don't want to drive it until i get the car aligned. i have an appointment next Monday the 8th at West End in Gardena..
i drove it up the street to see if i rubbed and i rub a lil bit.. when i drive up the road only about a couple hundred feet, the "VDC OFF" and "SLIP" light both turn on .. when i press the "VDC OFF" button, it doesn't do anything.. it doesn't turn off or on.. pretty much at the same time the VDC engages, which kinda feels like ABS...
Does anyone know what might be causing this..?
Has anyone had this problem before..?
we were thinkin that it could be the alignment/toe/camber way out of adjustment, thus causing the car to go into VDC and SLIP or something.. i would imagine that after installing all of this equipment that it would be all off until alignment..
anybody..???
thankx..
Alf
SPC toe bolts..
anybody..???
thankx..
Alf
http://www.spcalignment.com/PROD_DIR...txt&cmd2=72125
06g35
Feb 14, 2022 05:59 AM
Thebaws11
Nov 30, 2016 12:54 PM
