Brembo in a G35x questions...
Old Mar 3, 2010 | 12:54 PM
snotf's Avatar
hey guys, i'm wondering how feasible this is. i know it's fairly simple( just obtaining the calipers and lines( obv rotors and pads) from a brembo kit for a RWD sedan. i'm wondering if it is the same story for an X?
also, clearance? the calipers being dual piston are obviously a bit bigger, will there be a clearance issue with my stock X rims that i run? all g35s/350z's that got the brembo kit had at least 18s, i believe.
any help on this will be really helpful on my decision with tax time coming up i had a caliper stick and run through two rotors in the rear, and the x is sidelined right now till i figure out till i figure things out. i figure i have about a week before i get impatient and go get another single piston caliper.
mods, please don't move this to the Brake section, i need the attention it will get from the X/sedan crowd here.
Old Mar 3, 2010 | 03:50 PM
semicycler's Avatar
I'm in the process of this upgrade now. Brembo's do not fit under stock 17" wheels. The front calipers are too big. 18" sedan sport wheels fit but with spacers.
Install should be straight forward, front calipers reusing the original caliper bolts, rear calipers needing new ones. And yes you need to trim the dust shield in the rear - or remove/replace with lots of work.
As far as I know, there are no specific issues because it's an 'X', other than normal BBK fitment under stock wheel issues.
Old Mar 3, 2010 | 04:40 PM
snotf's Avatar
So if the rear calipers need new bolts do you mean the bolts from the brembos then retapped or all new bolts retapped all the way through?
The dust shield can be trimmed easily enough, but if it doesn't detach easily this has to be done on the car... which means it wont be clean, right?
Any chance you are doing a write up of your swap?
Old Mar 3, 2010 | 05:04 PM
nghiars's Avatar
I havent done this myself but the only issues that come straight to mind is the rims fitting over them and dust shields. Brembos swap right onto non-brembo V35 coupes and sedans with the exception of the dust shields. I think you guys should be fine.
Old Mar 3, 2010 | 05:09 PM
Mustang5L5's Avatar
Does anyone here change the Master Cylinder?
I'd imagine the fluid volume requirements are slightly different between the calipers as the Brembo brake equipped G35's use a different MC than the non-brembo equipped G35's?
EDIT: Found my answer here
https://g35driver.com/forums/3890291-post11.html
There is a different MC, but the difference is 0.0626"...so it shouldn't be that noticable.
Old Mar 3, 2010 | 06:23 PM
semicycler's Avatar
Not an X but the same process: https://g35driver.com/forums/brakes-...swap-work.html
Old Mar 3, 2010 | 06:46 PM
bigwilly's Avatar
You don't need to change the master cylinder. You will also need 15mm spacers all around. I put in an extra 3mm spacer in the front just for a bit more clearance for the stock 17" wheels. I use them as my winter setup.
Old Mar 4, 2010 | 12:59 AM
nadeem132's Avatar
hey i am also in the process of puttin on some brembo calipers i have some 19 inch rims with the front offset being 35mm and the rear 40mm will the brembos clear and if not what do i have to do so i get the clearance
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
