/SPC Camber Arms Installation\
Old Mar 7, 2010 | 01:52 AM
AARONHL's Avatar
I installed SPC front camber arms last week. Thanks to everyone who talked me into buying the SPC arms!!!!!
After the alignment (before the arms were installed) the front camber was -1.25ºL, -1.66ºR. I installed the arms to give them the most positive camber without using the spacers. To make sure I have enough positive camber and room for adjustment, can I install the 2º fixed spacers and add some negative camber to the arms?????
Thanks,
Aaron
Old Mar 7, 2010 | 11:07 AM
G35Papa's Avatar
Yes but have a shop do the adjusting for you
Old Mar 7, 2010 | 07:14 PM
AARONHL's Avatar
Ok, I'm an idiot. I guess I was too tired to realize what I actually said.
What's the best way to get the most positive camber to be within the correct specifications?
Old Mar 7, 2010 | 07:25 PM
G35Papa's Avatar
Adding the SPC spacers/shims will give you the most positive adjustment.
Old Mar 7, 2010 | 07:41 PM
AARONHL's Avatar
The spacers are a POSITIVE 2 degrees, correct?
Old Mar 7, 2010 | 07:45 PM
G35Papa's Avatar
Correct
How much are you going to lower the G?
Old Mar 7, 2010 | 07:46 PM
AARONHL's Avatar
OK, so I wasn't loosing my mind!
Any tips for the spacer installation?
Old Mar 7, 2010 | 07:49 PM
G35Papa's Avatar
Hella tips
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/X3lNK1nCta0&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/X3lNK1nCta0&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
AARONHL's Avatar
I lowered it about 1.75 inches...
Old Mar 7, 2010 | 07:51 PM
G35Papa's Avatar
You should be able to get close to stock specs with just the arms but if you want to be 100%, the shims will get you there.
Old Mar 7, 2010 | 07:59 PM
AARONHL's Avatar
You are the man! Thanks!!!
Old Mar 7, 2010 | 08:00 PM
G35Papa's Avatar
You're welcome. Happy modding
Old Mar 10, 2010 | 09:08 PM
AARONHL's Avatar
I installed the spacers today. There is definitely a positive and negative swing now.
I used five thin washers on the passenger side and only two on the driver side for the VDC sensor. Is that normal? If I didn't use the five, it would have been touching the bearing. It's difficult to see exactly how much room there is between the sensor and the bearing. I don't have any warning lights on the dashboard, but I haven't tested if VDC works either. I guess I'll try that soon when it rains.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
