Tokico HP vs OEM shocks/struts (review)
Old Mar 29, 2011 | 04:22 PM
  #106
Ginevan's Avatar
Did you really bump this thread for that?
Old Mar 29, 2011 | 06:08 PM
  #107
Abax84's Avatar
LOL no, I just think I'm funny.. I was about to start shopping for the HP blues, and there was a lot of conflicting posts in this thread. I just had a spacers installed, and fenders rolled, and alignment done. Did anyone ever confirm whether or not the HP G-Shocks alter your ride height? I don't want to have the car re-aligned.. But I need shocks, mine are toast.
Old Mar 29, 2011 | 08:57 PM
  #108
Ginevan's Avatar
You probably won't get a straight answer to that question. Some saw a drop, some didn't.
Old May 20, 2011 | 02:25 PM
  #109
qbanboy's Avatar
OK so here is my question? I want to get the S-tech teins but i need new struts, will those hp tokico will raise my car more than the oem struts or will be the same if i get the oem struts?
And another question is i saw they have the adjustable struts tokico D-Specs on eBay.. Does anyone know about this one? if you do please tell me if you can adjust the struts from soft to hard....
Which one is better he D-spec or the HP ?
Old May 20, 2011 | 05:02 PM
  #110
Ginevan's Avatar
Your first question has been answered about a dozen times.
Your second question could have been answered by going to tokicos website.
Dspecs are adjustable and b.etter. But its very hard forget to the rear struts
Old Jun 24, 2012 | 07:32 PM
  #111
rhamkybeatz's Avatar
Do the tokico d-spec for 350z would work for the g35?
Old Jun 24, 2012 | 07:42 PM
  #112
Idk. Because when I searched you have to search diferemt for the d spec , the d- spec for 350z are cheaper than the g35 ones
Old Jun 24, 2012 | 07:50 PM
  #113
There 2 different models du3742 for 350z and du3746 for g35
Old Aug 6, 2012 | 09:14 PM
  #114
NGK's Avatar
NGK
not to beat a dead horse, but looking at changing out some things on an '06 6MT sedan.....
car has 18's and a 6MT
however, the tokico's are black all around....are they the "sport suspension'? and if so, would it be wise to change out for the z revised/unrevised spring setup? which one?
Thanks, NGK
Old Aug 7, 2012 | 10:37 AM
  #115
gary c's Avatar
Just installed Tokico D-Specs on my G35 coupe. The shocks for the Z are slightly (1/4") shorter so I went with the ones for the G. Already have issues getting in and out of my driveway. Followed the instructions on the settings, may go a couple clicks stiffer but a nice ride with my Tein 350Z H-Techs....Gary
Old Aug 7, 2012 | 01:09 PM
  #116
crazynuts16's Avatar
^ Gary,
did the 350z h-techs drop the car significantly compared to the stock springs? I am asking you since I have same front/sides as you. I daily the car and don't want to make it go too low but want to get rid of some wheel gap at the same time. Let me know if you have any advice for me.
Anyways, my question for this thread is that are the sports suspension shocks better than the tokiko blues in any way? or vice-versa? Which ones are stiffer, stable, better ride quality, etc?
Old Jun 25, 2013 | 04:26 PM
  #117
JKL1031's Avatar
Originally Posted by tyau
That's exactly the point.
The length of the shaft and/or shock body do not affect the spring rate. It only dictates how much travel the suspension has before the piston shaft bottoms out.
The G shocks have more droop travel but less compression because of the longer piston. The Z shocks have more compression travel but less droop travel because of the shorter piston.
The key point is that as long as the same set of springs give the same ride height when installed on the same vehicle, it doesn't change it's stiffness regardless of piston length of the shocks.
Do you not have the addition of the 1/4" compression added in conjunction with the weight of the vehicle? U have the weight of the vehicle plus the 1/4" compression. Your applying the weight of the vehicle starting with an initial 1/4" compression, as before your adding the weight of the vehicle on a fully extended spring. With a 300lb/in spring, that's about 75 pounds pushing up at each wheel. I agree it will settle to the same ride height, but the spring will definitely be preloaded.
Sorry to bump an old thread but I'm going through the same issue.
Old Jan 17, 2014 | 07:45 PM
  #118
jconn02's Avatar
soooo this thread is confusing as no other but what i could gather is...
A. z hps will be stiffer than g hps.
B. depending on how bad off your oem shocks are it could either raise the car due to worn shocks or the ride height stays the same.
C. z hps put on a g will drop the rear an extra .5 inch? saw that somewhere..
and now my question.
if installing z hps on a g does in fact drop the rear an extra .5 from just the z hps, would that eliminate the need for spring mount mod on uneven drop springs like tein 350z springs? on a diff thread someone was saying that they installed the rsr 350 springs on a g and the rear didnt drop. would make sense if the g shocks/struts were taller/longer in the back.
Old Jan 19, 2014 | 02:09 AM
  #119
JOKER's Avatar
CLUB MODERATOR
with G and Z springs your rear sits always higher then front. No matter what springs you go with. Z springs drop your G lower than G springs would, but your rear still remains higher that front. So rubber mount mod is still duable and is needed if you want to see your rear lower.
Old Apr 5, 2014 | 06:46 PM
  #120
JOKER's Avatar
CLUB MODERATOR
Longevity review:
As it turns out these shocks don't live long with lowered springs.
Pretty much every forum out there reports the same thing. Shocks either blow or start leaking quite fast when coupled with lowered springs. In my case they were paired with Tein H-tech springs and went out after 70k. OEM shocks lasted 90k but they were not used with lowered springs the entire time.
So. If you are looking for shocks that will last longer than that go with Tokico D-Spec. They are adjustable and reportedly last forever when paired with lowered springs, plus Tokico offers limited lifetime warranty on them.
Another option is Koni Yello. They are also adjustable just like Tokico D-Spec and Koni also offers Lifetime warranty on them, which sounds to be better than Tokico warranty.
If you don't want adjust-ability and lifetime warranty go with KYB shocks. They seem to similar to Tokico HP blue, but reportedly last longer (don't quote me on that, do your own research)
I'm going with Koni Yellow due to availability and lifetime warranty.
