Tokico HP vs OEM shocks/struts (review)
Old Dec 29, 2010 | 03:16 PM
  #61
sloppymax's Avatar
I would put my money that the springs were not seated correctly either before or after the shock install. There is a perch that the end of the coil of the spring sits in, which if not done correctly on all four corners could lead to height discrepancies.
Old Dec 29, 2010 | 03:18 PM
  #62
takaG35's Avatar
interesting.
I just assumed the HP shocks would lower just a tad, but if not then that's fine.
Like for Hondas, when they put aftermarket shocks like tokicos, it would lower it just a tad more. Of course a totally different vehicle.
If you anyone has pictures of their setup 350 htechs/ G or Z HPs would be coo.
Some say HP's will lower, some say no. which is it? hahha I guess I'll just have to wait and see. If it does lower, cool, if not, owell
Old Dec 29, 2010 | 03:23 PM
  #63
Jeff92se's Avatar
Red Card Crew
Shocks do not lower/raise the car. Not on any car.
Unless you have some hooker air shocks or something
Old Dec 29, 2010 | 05:58 PM
  #64
Ginevan's Avatar
I'm fully aware of how they seat. They were seated correctly before as well as after.
Old Dec 29, 2010 | 06:02 PM
  #65
JOKER's Avatar
CLUB MODERATOR
read couple of posts above.
Me and other members notice a light raise over stock shocks.
it's not a primary function of the shocks and more like a side effect but Tokico HP did raise my car a little.
Old Dec 29, 2010 | 06:26 PM
  #66
Ginevan's Avatar
Not suggesting the reason that other users are experiencing a raise. But didn't you say that your shocks were blown like no other?
Old Dec 29, 2010 | 06:29 PM
  #67
Mr. Samster's Avatar
is it because the shocks are new and are not worn yet causing it the car to be raised a little?
Old Dec 29, 2010 | 06:30 PM
  #68
takaG35's Avatar
my shocks seem to be okay right now (93k)
but many people have been telling me the stockies will
be blown soon, so I purchased the HP's.
I doubt I'll see a raise since my shocks aren't blown out.
Should be the same height...
Old Dec 30, 2010 | 11:04 AM
  #69
Ginevan's Avatar
unlikely.
Old Dec 30, 2010 | 06:24 PM
  #70
takaG35's Avatar
any pics of your setups? thanks*
Old Dec 30, 2010 | 11:24 PM
  #71
Ginevan's Avatar
I've said before, you may have just missed it, that I'll get pictures once it's clean.
Old Dec 31, 2010 | 11:37 AM
  #72
viceversa's Avatar
thread is full of fail.
Old Jan 1, 2011 | 03:47 PM
  #73
Ginevan's Avatar
Instead of bitching about it, fill it with success then.
Old Jan 1, 2011 | 06:32 PM
  #74
JuicedAthletics's Avatar
There is ALOT of bad information on this thread. If you drive a G buy the G shocks, if you drive a Z buy the Z shocks. There is about an inch difference in the length of the shaft between the G and Z HPs. I know, I have had and installed both. The ride is much more harsh with the Z shocks. The rear of my car sat 1/2 inch lower with Z HPs than G HPs, same springs seated correctly.
Old Jan 1, 2011 | 09:13 PM
  #75
High_Boost's Avatar
I wonder if the difference in height would make the z shocks last longer with the z springs, since they were designed to run at that height?
in my honda days, when you lowered a car on a full height strut, the struts wore out pretty fast
