Clunk sound from rear while in reverse
Old Apr 19, 2010 | 06:03 PM
b-lo's Avatar
Im getting a clunk sound while backing my car out of a driveway. Also if you go to the rear passanger side and push down and pull up on the car you can duplicate it. What might it be? Compression rod that Ive been reading about>?
Old Apr 19, 2010 | 06:07 PM
b-lo's Avatar
and it seems to be coming from the bottom of the susp
Old Apr 20, 2010 | 10:20 AM
geew1z's Avatar
broken spring? Very hard to say without seeing / hearing it
Old Apr 20, 2010 | 02:54 PM
sdnpaul5at's Avatar
Compression rod noise would come from the front, my guess would be your endlink is no good, once you have it up on the hoist you'll be able to pin point the problem.
Old Apr 20, 2010 | 03:29 PM
b-lo's Avatar
Hmm I will check under the car again today since I did a furter search to see what they look like. Thanks
Old Apr 20, 2010 | 04:43 PM
b-lo's Avatar
Got outside today. The endlinks are not broke but you can wiggle it a little bit. And the sound is def coming from there cause if you shake the car up and down while your hand is on it you feel the clank
Old Apr 20, 2010 | 04:55 PM
vp-g's Avatar
mine too keeps the same niose..when ever i reverse out the drive way any step on the brakes I hear the clunk clunk..
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
atk08
Jul 30, 2015 03:12 PM
cyrus32
Jul 18, 2015 06:22 PM
