camber degree help! do i need front cambers?
Old May 6, 2010 | 09:50 PM
jatt2nv's Avatar
lowered on z s techs heres my camber adjustment sheet i got from this car place by my house there asking 800 for the spc front and rear kit installed
not sure if i really need front camber kits? i know i need the rear least ive been told hoping someone can tell me what i need?
http://i41.tinypic.com/10igc9z.jpg
Old May 7, 2010 | 02:01 PM
Gsedan35's Avatar
Everyone is different concerning what is too much camber. And you should know that the sedan, coupe and Z all have different oem camber specs (sedan also has different rear toe specs).
Some will say your fine, just get your toe in settings to spec.
Other's will say to set front toe in correctly and get a rear camber arm and elongated toe cam bolt setup.
I wouldn't want that much camber on the street ( my tire pyrometer didn't how I needed them) So, I would get front and rear arms with elongated toe cam bolts and reset to,....
Front: -1.3 degree camber
1mm combined toe in
Rear -1 degree camber
1.6mm combined toe in
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
cbax
Aug 17, 2015 07:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
