DBA/Hawk Problems
Old Jun 10, 2010 | 03:19 PM
FlaviusFlav's Avatar
DBA/Hawk Problems
So I have been trying for over a month to find a solution to this problem.... I installed DBA 4000 rotors and Hawk HPS pads on the front of my '04 Coupe, and for some reason, they have been "clicking" ever since I first drove off from the dealer that installed them for me. And before you ask, yes I followed the burnishing procedures to the letter, and I even contacted both Hawk and DBA, but both companies want to blame the other, so I can't get a straight answer. I also took the car back into the dealer, and they said that the brakes were "dragging" and that most likely the slots in the rotors were hitting the pads and causing the noise. Has anyone had any experience with this? And can you help me find a solution for this quite annoying problem? I'm really getting tired of the noise when I'm driving.
Old Jun 11, 2010 | 11:43 AM
G35fromPA's Avatar
I'm not sure this is what your problem is, but I've heard slotted rotors can make that noise, which is why I chose not to get them. Do you have a set of older OEM pads that you can try to see if it's the pads? Also, has the caliper been through a lot of miles and grime? Maybe the pistons are getting a little sticky.
Old Jun 11, 2010 | 11:45 AM
JBF's Avatar
JBF
It is the pads rubbing against the slots.
/thread
Old Jun 11, 2010 | 08:07 PM
I know it's the pads hitting the rotors, but with all of the people running this exact setup, I haven't heard of anyone complaining about any noise. So given that this is a rare situation, I'm just trying to figure out how to fix it. But thanks for the responses guys.
Old Jun 12, 2010 | 12:47 AM
tonke73's Avatar
Are the rotors installed on the correct side? Some rotors if not all, are directional.
Old Jun 12, 2010 | 04:36 AM
JBF's Avatar
JBF
I have the same setup and there's noise...but i had slotted rotors on previous cars and made similar noise
Old Jun 12, 2010 | 08:58 AM
TwoFiveBravo's Avatar
I have the DBA 4000 rotors with pMU pads and get the same sound when braking. Sounds liks a faster version of the wheel on wheel of fortune or something like that. Just clicks. I assumed its because of the slots.
Old Jun 12, 2010 | 09:42 AM
SDGenius's Avatar
if you have Brembos, then you can get shims to help quiet them down.
Old Jun 14, 2010 | 04:33 AM
Just to clarify a little bit.... The noise only happens when the car is moving, it goes away when the brakes are applied, or rather when the car slows down, idk. And they are not Brembos... Just wish I could afford to do a bbk and be done with this.
Old Jun 14, 2010 | 06:57 PM
onthe3rdday's Avatar
Caliper hardware kit is rubbing on the rotor. The "kit" is the bracketing that the pads float on.
Old Jun 14, 2010 | 08:01 PM
JBF's Avatar
JBF
^ wrong
The 4000 series have small slots(wipers) that face the opposite direction. that is what makes the sound
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
