GOING WITH BC RACING COILOVERS...help
Old Jun 10, 2010 | 10:14 PM
jbizz's Avatar
im also gettin BC coils for an 1inch-1.5 inch drop all around, and was told i need front/rear camber kits to save tires too
Old Jun 10, 2010 | 11:49 PM
alfhasg35's Avatar
for the price of front camber kits and a good alignment, you will have saved yourself a set of tires in the long run.. the cost of saving tires more than makes up for your camber kits, front and rear.. like they say.. do it right the first time.. you may or may not need it but like i said.. by the time u figure out u need the kits, you will have gone thru a set of tires...
i asked this same question about camber kits several times in different posts, threads and pm's.. i just saved myself the grief and bought all the stuff..
Old Jun 10, 2010 | 11:55 PM
jbizz's Avatar
Amen!
Old Jun 11, 2010 | 02:22 AM
rtnguyen1's Avatar
Thanks! I ordered the SPC Camber kit.
Old Jun 11, 2010 | 09:59 AM
jbizz's Avatar
how much did the SPC camber kit run you? and does anyone know excatly how low you can be lowered on BC coils?
Old Jun 11, 2010 | 01:47 PM
Xet's Avatar
Xet
Front or rear? I would recommend rear but front it depends how low you want to go. If you are planning going lower than ~2 inches than SPL would most likely be a better choice.
https://g35driver.com/forums/brakes-...coilovers.html
There are a few pics posted by people of bc's on their lowest in that thread
Old Jun 14, 2010 | 07:58 PM
blaccG35's Avatar
how much would you need to drop it if you want to get rid of all the wheel gap with oem 19's?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NJ6MT
Oct 9, 2015 05:02 PM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
