Replacing my Upgraded Braking system
Old Jun 21, 2010 | 11:39 PM
exopina's Avatar
Ok Everyone, been a while since i last visited. Need some feedback from everyone.
In 07 i replaced my stock pads and rotors for my 04 G35 Sedan AT with the brake Pro stage 2 kit( 4 slotted and cross drilled rotors, hawk HPS pads, steel braided line) from everythingg35.com
they have serve me well but the rotors finally are starting to warp. And being that technologies change. My questions are
1. trying save some cash. its there a comparable rotor to the brake pro rotor that has just as good as a reputation but at a better cost?
2. so far the hawk HPS pads have been good but i did notice fade when it rains. Are there better pads i should be looking at, that can provide performance with everyday drivability, with little brake dust and fade
3. do i really need the cross drilled rotors, will i notice that much of a difference between slotted and cross drilled vs. solid rotors? I know they are definitely lighter in weight which is a plus
Any feed back would be greatly appreciated
Old Jun 22, 2010 | 12:32 AM
tonke73's Avatar
1. I hear good things about Rotora and centric rotors but don't have any personal experience with them. I plan to get the Rotoras when I need new rotors.
2. Hawk HPS pads suck and you should get them off your car asap. I had them on my car and they were worse than OEM. I have Project Mu NS rear pads and OEM front pads on my car. The Project Mu pads have excellent initial bite and very good pedal feel. I was also looking at the Endless SSY pads as I hear very good things about them also.
3. If you don't track your car, you won't need cross drilled or slotted rotors. I had slotted rotors on my G35 and didn't notice a difference in stopping power with them on.
Old Jun 22, 2010 | 09:41 AM
cato's Avatar
SouthernComfort Moderator
I discovered that most all shops in Houston refused to turn my slotted rotors.
My new rotors are not slotted and they perform just as well. I do not track my sedan but enjoy spirited driving!
Old Jun 22, 2010 | 09:48 AM
exopina's Avatar
Cool thanks for the info. looks like the rotora rotors are comporable in price witht the BrakePro rotors. I am leaning torward purchasing them. I just hope they are just as light in weight. The brake Pro Pillar vane rotors were alot lighter than stock. If not i might just suck it up and buy the same rotors, after all i had them on the car for 3+ years.
EnCr1pt3d
Jul 8, 2019 02:48 PM
mjfenix
Aug 17, 2017 05:49 AM
papo020
Jul 17, 2015 10:30 PM
emorehs
Jul 17, 2015 09:45 AM
si_driver
Jul 14, 2015 12:29 PM
