How long should I wait
Old Jun 30, 2010 | 07:19 AM
Matthew121's Avatar
For my new springs to settle, before I do the rear spring mount mod?
Old Jun 30, 2010 | 12:35 PM
idrive_MD's Avatar
give it a week or so if you drive the car often...it doesnt take much longer than that.
and good luck with the spring mount mod, those things are a bitch to cut, certainly with a dull-ish hack saw blade.
Old Jun 30, 2010 | 12:41 PM
cremaster's Avatar
w/ my coilovers it took about 3 weeks to settle and i drive about 200 miles a week.
Old Jun 30, 2010 | 01:28 PM
Xet's Avatar
Xet
couple of weeks and you should be pretty good
Old Jun 30, 2010 | 01:35 PM
The Stimulation's Avatar
i'd drive at least 500 miles. somewhere between 500-1k is good enough.
Old Jun 30, 2010 | 02:14 PM
Matthew121's Avatar
Ok sweet, thanks guys!
Old Jun 30, 2010 | 02:25 PM
irishsig's Avatar
FYI, to make the spring mount mod cutting easier keep the hacksaw blade lubed with wd-40.
Once it starts drying out you'll def feel the tension/resistance in the blade.
Having access to a table vice makes a huge dif too.
Old Jun 30, 2010 | 02:27 PM
Matthew121's Avatar
I have a table vise on the work bench at home, I also have a sawzall I will prolly use. I figure with both of those + lube, it should be pretty quick work.
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
dcsbh1
Oct 1, 2015 03:15 PM
