Wheel alignment explanation
Old Jul 7, 2010 | 03:52 PM
Deezflip's Avatar
Not really your typical -if my alignment is ok- question. How do you know if the toe alignment has a slight toe-in or a toe out setting? What examples in degrees are toe-ins and toe-outs?
For example if 0.00, is dead-on straight, does that mean the driver side should be +0.01 and the passenger side should be -0.01 for a toe-in configuration? I'm thinking in terms of a clock where 12 o'clock is 0.00 and clockwise is positive, and counter-clockwise is negative. Does this make sense or am I completely off?
Old Jul 7, 2010 | 05:59 PM
brandon1978's Avatar
toe-in = neg or -, both tires will be - and / \
toe-out = pos or + both tires will be + and \ /
Old Jul 7, 2010 | 10:10 PM
Deezflip's Avatar
^Negative for toe-in? What I don't understand is that the "before" toe is in (negative)red which is apparently misaligned on this person's alignment readout...
and the "after" is back in the postive 0.03(green)
or even on this other person's alignment printout...
Old Jul 8, 2010 | 09:48 AM
Deezflip's Avatar
bump
Old Jul 8, 2010 | 11:38 AM
Sorry I had the pos and neg flipped before. Your specs looks pretty good. It looks like they tried to set it right in the middle of the specs. The rear camber is slightly out of spec, but not too bad. More toe-in in the front would be better for wear, but it is pretty good where they set it.
Old Jul 8, 2010 | 12:29 PM
Deezflip's Avatar
^gotcha, so positive is toe-in, ...the higher the degree, the more toe-in(left AND right side).
By the way, those alignment images aren't mine. I just used them as an example.
Old Jul 8, 2010 | 04:13 PM
Affirmative.
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 18, 2015 12:33 PM
