25mm spacers any downfalls?
Old Aug 15, 2010 | 09:23 PM
G3V's Avatar
G3V
I have a 2003 coupe and im putting on 25mm spacers all around (4x)
do these spacers reduce handling/ camber/ anything? what are the downfalls of using spacers?
Old Aug 15, 2010 | 09:28 PM
doeboy's Avatar
The only neg thing I have found is that I need 30mm in the rear. Other than that they are great. Just use lock tight when mounting the spacer to the hub. You really never check those, so the lock tight will make it stay in place.
Old Aug 15, 2010 | 09:36 PM
Jairen's Avatar
Just more weight added to each wheel. Depending on you wheels and tires, you may have to roll your fenders.
Other than that, great mod.
Old Aug 17, 2010 | 09:17 PM
sundown's Avatar
Ive had them on for a year and no problems at all... hope I didnt just jinx myself.
Old Aug 18, 2010 | 01:02 PM
G35fromPA's Avatar
They do have some side effects. Keep in mind that you are making the track width of the car wider, so you are affecting the scrub radius, and therefore there will be some dynamic camber and toe changes, possibly requiring an alignment. However, at the very least, by using the same size spacer F/R, you don't alter the track width difference. Using different size spacers F/R would change handling characteristics. For instance, running a wider track width in the back (more than 0.5" wider than the front) could lead to increased understeer.
Old Aug 18, 2010 | 09:27 PM
Beebo's Avatar
i wouldnt track the car with spacers
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
