Just got camber kit installed now need toe arm?
I'll clear things up a bit. The amount of camber you run will determine whether toe bolts or toe arms are needed. Pretty much anything beyond -4 degrees of camber will need to arms. Anywhere under, toe bolts are plenty and will get you back into factory spec for the toe.
A lot of these dealerships don't really know what they're talking about unfortunately. I've had some say that my coolant leaking was due to my intake....or that they don't know the size of the exhaust piping.
For your drop and camber, toe bolts are sufficient. I know you got that figured out but I figured I'd post this info for future reference in case anyone stumbles upon this thread.
What are the factory specs??? apparently the dealer couldnt answer that...im on oem sport suspension 06 coupe with 1/4" springmount mod to level the car and 245/35/19-f, 275/35/19-r....got an alignment recently and was told i need cambers...front left is -1.2, front right -1.5, left rear -2.0, and right rear -1.5...toe's are good, so what im told...am i good, or am i facing tire wear...just got new tires!
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
